seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Crazyflie Nano Quadcopter - 6x15 mm spare motor (BC-CM-01-A)
      • Crazyflie Nano Quadcopter - 6x15 mm spare motor (BC-CM-01-A)
      SKU 108100000
      The DSO Nano V3 is a pocket-size compatible 32bit digital storage oscilloscope
      $3.00
      DISCONTINUED
      The DSO Nano V3 is a pocket-size compatible 32bit digital storage oscilloscope. Based on ARM -M3, it’s equipped with 320*240 color display, SD card, USB port and recharging function. It’s compact, simple to operate; meets the basic demands of school lab, electric furniture repairment and electric engineering.
      This is a updated and cool version of DSO Nano which features a firmware and a embedded 2 Mbyte storage chip instead of micro SD card slot. The documents of this version in detail is on this page, please refer to it.
      NOTE:For DSO Nano with SD card slot, it is not available now. If you get one from our distributers’ stock, please click here to check the document.
      Updates in v3:
      • V3 used a new firmware with user-friendly interface, easier to operate
      • Upgraded firmware via virtual disk
      • Added build-in 2Mbyte storage chip instead of micro SD card slot
      • Black metal shell
      • Portable and lightweight
      • Color display
      • Waveform storage and playback
      • 6 triggering modes
      • 200Khz Analog Bandwidth
      • Complete measurement markers and signal characteristics
      • Built-in Signal Generator
      • Accessories available
      • Open Source
      Specifications
      • Display: 2.8’’ color TFT LCD
      • Display Resolution: 320x240 Display Colors 65K
      • Analog Broadband: 0 ~ 200kHz
      • Max. Sampling Rate: 1Msps 12 bit
      • Sampling Storage Depth: 4096 points
      • Transverse Sensitivity: 1uS/Div~10S/Div(1-2-5 stepping)
      • Vertical Sensitivity: 10mv/Div~10V/Div(x1 probe) 0.5V/Div~10V/Div(x10 probe)
      • Input Resistance: >500KΩ
      • Max. Input Voltage: 80Vpp(x1 probe)400Vpp(x10 probe)
      • Coupling Mode: DC
      • Triggering Mode: Auto,Normal,Single,None
      • Auto Measurement: Frequency, cycle, duty, Vpp, Vram, Vavg, DC voltage; Vertical Precise Measurement Cursor; Horizontal Precise Measurement Cursor; Rising/Falling Edge Trigger; Triggering Cursor; Triggering Sensitivity Cursor; Hold/Run
      • Inbuilt Test Signal: 10Hz~1MHz(1-2-5 stepping)
      • Waveform Storage: build-in 2Mbyte
      • PC Connection Interface: Connection through USB
      • Recharging Method: Recharging through USB interface
      • Dimensions:105mm x 53mm x 8mm
      Part list:
      • DSO Nano x1
      • Metal Stand x1
      • Screw x1
      • Probe cable x1
      • Sack x1
      Documents
      See More
      $50 Featured List
      $100 Featured List
      $200 Featured List
      Don’t miss out!
      Reviews
      See More
      Questions and Answers
      SUBMIT
      See More
      View History
      Documents
      SUBMIT
      Invalid email address.
