Garan - Audio Module
  • Garan - Audio Module
SKU 107990004
Garan- audio module is a kind of simple music player device whose design is based on a high-quality audio chip---ATS2301
$9.90
DISCONTINUED
Garan- audio module is a kind of simple music player device whose design is based on a high-quality audio chip---ATS2301. It can support 8KHZ~48KHZ sampling frequency MP3, WMA and WAV file formats. You can easily control the audio module by sending uart commands, such as switch songs, change the volume, play mode and so on. It seems a simple module, but it includes FAT filesystem, SD driver, audio decode and so on. Want to know how strong the module is? Please come to experience it!
  • Asynchronous serial port control
  • Support MP3, WMA and WAV fortmat music.
  • Compatibility with FAT16 and FAT32 filesystem.
  • Support microSD card and USB disk.
  • 16 levels volume control.
  • 8 kinds of EQ.
  • Support selecting music by filename or file number.
  • Support expanding PA.
  • Support Li-ion battery Power supply.
  • Support calendar function.
Documents
Please click Garan Tech for more info about this product and technical support.
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Questions and Answers
SUBMIT
I have a weird issue with Garan Module
It is producing 5 slow low beeps every ~5 seconds.
This happens if playing and no playing
What is this noise?
on Oct 19,2016
Replyupvote ()
Hi,the Max Sheet Dimension is 40cm x 60cm,and transparentcolour is provided,other colours also if you want.
on Oct 20,2016 10:42 AM
Replyupvote ()
Hi! Do all the modules you buy have this issue? Maybe you can try another micro SD card or music file.
on Oct 20,2016 10:48 AM
Replyupvote ()
I'm having the same problem. Did you figure out any solution?
Replyupvote ()
Reply
0
Feel free to check it out at https://github.com/mcuapps/Gar...
on Oct 19,2016
Replyupvote ()
Hi , the width is in the range of 0.2 and 0.3 mm .
Replyupvote ()
Hi,Chen, Thanks your jobs, we already add the library link to description page.
on Oct 20,2016 10:47 AM
Replyupvote ()
Reply
0
Is UART 5V tolerant? Meaning can I directly connect to Arduino?
on Oct 19,2016
Replyupvote ()
I'm sorry to not have enough information.
plan to plywood of 2mm-10mm.
Replyupvote ()
yes
Replyupvote ()
Reply
0
Is it possible to get sample accurate sound triggering between more than one module (or use some kind of external sync), so that you could play back 4- or 8- channel audio by having multiple modules working together?
on Oct 19,2016
Replyupvote ()
Hi Richard, no problem, we have 2mm material like acryl.
Replyupvote ()
It hard to control time accurately.Because we can't make sure the time between receiving command and starting playing being constant.We are interesting how to use external sync in these module?
Replyupvote ()
Reply
0
Looks like a really interesting module. Does 'Support Li-ion battery Power supply' means that the module has a battery charging circuit?
on Oct 19,2016
Replyupvote ()
I need Black acrylic too, do you have it?
on Oct 20,2016 10:41 AM
Replyupvote ()
Hi, Shigeru. It just mean you can power it with Li-ion battery.
Replyupvote ()
Reply
See More
View History
Recommendations
SUBMIT
Invalid email address.
