Grove - 6-Axis Accelerometer&Gyroscope
SKU 105020012
9.90
29 Available
$9.90/ 1pcs+
$8.91/ 10pcs+
$8.41/ 20pcs+
Grove - 6-Axis Accelerometer&Gyroscope is a cost-effective Grove sensor integrated with a 3-axis digital accelerometer and a 3-axis digital gyroscope.
With a serious low power consumption digital chip LSM6DS3 and power supply regulator inside, it features high sensitivity, green tech and low noise interference. It can be configured to different sensitivity levels of acceleration and different angular rate measurement range. Provided with detailed SDK, it can make the prototyping process quicker and easier.
This product can be used for different applications for tilt, motion, and tap sensing, such as robotics, IoT devices and consumer electronic devices.
  • Grove interfaced and cost-effective.
  • Digital-output for 6 DOF motion data.
  • ±2/±4/±8/±16 g full scale leaner acceleration sensing range for various environment.
  • ±125, ±245, ±500, ±1000, ±2000 degree per seconds(dps) for angular rate measurement range make it versatile.
  • Detailed SDK for easier programming.
  • Regulated power supply for reliable data to be collected.
  • Programmed interrupts for different event.
  • 8 kbyte data buffering.
Analog supply voltage: 5V/3.3V(DC)
Power consumption: 0.9 mA in combo normal mode and 1.25 mA in combo high-performance mode up to 1.6 kHz
Linear acceleration measurement range ±2/±4/±8/±16 g full scale (typical value)
Angular rate measurement range ±125, ±245, ±500, ±1000, ±;2000 dps(typical value)
Linear acceleration sensitivity 0.061(FS = ±2), 0.122(FS = ±4), 0.244(FS = ±8), 0.488(FS = ±16) mg/LSB
Angular rate sensitivity 4.375(FS = ±125), 8.75(FS = ±245), 17.50(FS = ±500), 35(FS = ±1000), 70(FS = ±2000)
Platform Seeeduino/Arduino Rasberry Pi LinkIt One Beaglebone
Supported status Supported Supported Supported Supported
Notes If no version number is not represented for a specific platform, it means this product support all versions within this platform. But you will need additional corresponding Grove shield board such as Grove - Base shield v2.
Technical Details
Dimensions140mm x 85mm x 10.30mm
WeightG.W 8g
BatteryExclude
Grove - 6-Axis Accelerometer&Gyroscope1
Grove - cable1
ECCN7A994
HSCODE9031900090
Certification
RoHSCompliant
Reviews
Questions and Answers
SUBMIT
0
Hi, We have purchased this for our Grove Pi kits but we couldn't find any python library. Please help.
on Sep 07,2017
Reply upvote ()
Sorry,we only provide library for Arduino,you need to code by yourself with python.
on Sep 08,2017 10:52 AM
Reply upvote ()
It didn't indicate clearly about sensor is for Arduino, it stated for GrovePi. After we have bought it so many, then now you said so?
on Sep 13,2017 16:01 PM
Reply upvote ()
Sorry for the inconvenience caused by us.We do mentioned it in the wiki , you can see the caution below the platform support. quote # It is not possible to provide software library / demo code for all possible MCU platforms #.Thanks for your understanding in advance.
on Oct 12,2017 14:15 PM
Reply upvote ()
Hello, I have the same problem than you. I need to make it work with a Grove Pi. Did you find a solution and can you share it please ? :(
on Nov 04,2017 00:44 AM
Reply upvote ()
Reply
1
Does it work with arduino mini?
on Nov 08,2016
Reply upvote ()
yes,It can work with arduino mini
on Nov 09,2016 13:50 PM
Reply upvote ()
Reply
    View History
    SKU 105020012
    $9.90
    29 Available
    $9.90/ 1pcs+
    $8.91/ 10pcs+
    $8.41/ 20pcs+
    • Description
    • Technical Details
    • Learn
    • Reviews
    • Questions and Answers
    SUBMIT
