Grove - Differential Amplifier
SKU 103020016
14.90
13 Available
$14.90/ 1pcs+
$13.41/ 10pcs+
Find setting up an amplifier IC on the breadboard a troublesome and totally no-need-to-repeat job? This Grove module can save you clutter to settle up such an IC by integrating the whole operating circuit. It's designed for precise differential-input amplification. Input the differential signals of your sensor to this module through the male pins, then your Arduino will get a precisely amplified output from the Grove interface. The gain scale factor is selectable. You can get a 35 times or 1085 times amplification via a switch on the board
  • High amplifying precision
  • Selectable scale factor
  • Can be conveniently read by Arduino
  • Strong input protection: ±40V
Application Ideas
  • Sensor signal amplifier
  • Signal comparison
  • General purpose amplification
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Technical Details
Dimensions130mm x 90mm x 11mm
WeightG.W 10g
BatteryExclude
Grove - Differential Amplifier1
Grove - cable1
ECCNEAR99
HSCODE8543909000
Certification
RoHSCompliant
Reviews
Questions and Answers
SUBMIT
View History
SKU 103020016
$14.90
13 Available
$14.90/ 1pcs+
$13.41/ 10pcs+
  • Description
  • Technical Details
  • Learn
  • Reviews
  • Questions and Answers
SUBMIT
