Grove - Dust Sensor(PPD42NS)
Rating:
88% of 100
Rating:
88% of 100
$11.50
In stock
100+ Available
This Dust Sensor gives a good indication of the air quality in an environment by measuring the dust concentration. The Particulate Matter level (PM level) in the air is measured by counting the Low Pulse Occupancy time (LPO time) in given time unit. LPO time is proportional to PM concentration. This sensor can provide reliable data for air purifier systems; it is responsive to PM of diameter 1μm.
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Note
This sensor uses counting method to measure dust concentration, not weighing method, and the unit is pcs/L or pcs/0.01cf.
Please pay attention to the warnings listed here.
  • Grove compatible interface(extra wire with connecter)
  • Supply voltage range: 5V
  • Minimum detect particle: 1um
  • PWM output
  • Dimensions: 59(W)x45(H)x22(D) [mm]
Application Ideas
  • Air Purifier
  • Air Quality Monitor
  • Air Conditioner
  • Ventilator
Platform Supported
Dimensions 59mm x45mm x22mm
Weight G.W 28g
Battery Exclude
VCC 4.75~5.75V
Standby Current Supply 90mA
Detectable range of concentration 0~28,000 / 0 ~ 8000 pcs/liter / pcs/0.01cf
Operating Temperature Range 0~45 °C
Output Method Negative Logic, Digital output, High: over 4.0V(Rev.2), Low: under 0.7V
Detecting the particle diameter >1μm
Dimensions 59(W) × 45(H) × 22(D) mm
Humidity Range 95% rh or less
Grove - Dust Sensor 1
Grove Cable 1
ECCN EAR99
HSCODE 9031900090
ROHS 1
Smart Crops: Implementing IoT in Conventional Agriculture!
Our mission with nature is to preserve it, designing and implementing technologies and monitoring methods with the help of IoT via Helium.
Air Quality Box
Monitor air quality around you
Air Quality Test Box
Make a smart box to detect the air quality in your house
Grove - Dust Sensor
Product Faqs
Sort by
