Product Details
Wiki & Learn
Reviews
Download PDF
Have you ever encountered a time when you couldn't connect the cable to the board or components due to the difference in connectors?
We got the solution for you.
The Grove Female Header allows you to convert a grove cable with a female connector to a male connector, making it a breeze to connect either to a board or to a component.Make the project you want to do can be completed perfectly.
Types of headers available
We offer the following types of Grove Female Headers.
SKUHeaderMounting TypePieces per SKUPrice
110990030Female Header (4-pin/ 2mm)DIP10$1.5
110990037Female Header (4-pin/ 2mm/ 90D)DIP10$1.5
114020163Female Header (4-pin/ 2mm)SMD20$2.9
114020164Female Header (4-pin/ 2mm/ 90D)SMD20$2.5
114020161Female Header (4-pin/ 2mm)SMD600$49
114020162Female Header (4-pin/ 2mm/ 90D)SMD800$55
Difference between the regular version and the 90D version of the DIP header
There are mainly two different versions of the Grove Female Header. They are the regular and the 90D version. When the regular one is soldered onto a PCB, the header sits perpendicular to the PCB, whereas when the 90D version is soldered onto a PCB, the header sits parallel to the PCB.
What is Grove?
We have developed more than 400 Grove modules, covering a wide range of applications that can fulfill various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you with guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
Which type of Grove cables can be connected to this header?
When using this Female Header, you can use the following Grove cables to prototype your projects.
Parts List
10 x Grove Female Header - DIP
Documents
Certification
HSCODE8536901900
USHSCODE8536904000
UPC841454107415
EUHSCODE8536909500
COOCHINA
Grove Female Header - DIP-4P-2.0mm-10 Pcs
SKU 110990030
This is a 4-pin, 2.0mm pitch, DIP Grove Female Header pack with 10pcs, which is suitable to perform wire transfers and get your board to connect to components
USD$0.99
