Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Angle Output Provides high accuracy roll/pitch/yaw angle output
  • High Performance Offers low-variance and stable accelerometer and gyro measurement
  • Shock Resistant Designed with a reinforced structure for stable and reliable installation
  • Industry Grade Suitable for robotics and AGV applications with CAN interface
  • 60V Compatible Can be connected directly to battery power system
Product
Hexfellow Y200 IMU
Voltage
12 - 60V
Operating Temperature
-20℃~85℃
Mechanical Dimension
60mm x 60mm x 15mm
Communication Interface
CAN
Max Output Frequency
200 Hz
Hardware Overview
Certification
HSCODE9031809090
USHSCODE9031808085
UPC
EUHSCODE9013101000
COOCHINA
Hexfellow Y200 IMU
x1
XT30 Connector
x2
USB Type-C to Type-A Cable
x1
Hexfellow Y200 9-axis IMU
SKU 101090143
The Y200 is a 9-axis gyroscope specifically developed for robots. The device supports a maximum power supply of 60V and uses a standard XT30 CAN interface for quick integration into a robot network. It features an internal potting process for excellent shock resistance, and its casing is designed with a reinforced structure for stable and reliable installation.
USD$160.00
You may also add
