Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Core Features
  • Ultra-High Accuracy: 0.1° roll/pitch, 0.5° reference-free heading, 1° magnetic heading.
  • Industrial-Grade 9-Axis Sensing: 3-axis gyro/accelerometer/magnetometer + SINS (strapdown inertial navigation system).
  • Advanced YFusion® Algorithm: Built-in fusion & error compensation for stable data.
400Hz Max Data Output: Up to 400Hz raw sensor data (default 200Hz, customizable).
  • ROS1/ROS2 Compatibility: Full support + C/C++ protocols & tutorials for quick integration.
  • Multi-Platform Development Support: Includes Windows GUI, STM32/I2C, Python, Arduino, MATLAB/Simulink examples.
  • Flexible Interfaces: UART/I2C/RS485 (switchable) + sync signal input.
  • Factory-Calibrated: Rigorous pre-delivery testing + user manual & technical support.
Overall Specifications
ParameterH30
ModelH30 MINIH30WP
Dimensions24.5*24.5*14.5mm63*55*24.5mm
HousingUltra-compact metal caseStandard metal case
Output InterfaceType-C/SH1.0 6PINAviation waterproof connector
Power Consumption186mW210mW
Reserved InterfaceUARTUART/RS485
Input Voltage4.5–5.2V DC5–26V
Axis Count9-axis (all models)
Operating Temperature-40°C–85°C (all models)
Command ConfigurationSupports serial command configuration: calibration, setup, mode switching, etc. (all models)
IMU Data Output Max Rate400Hz
IMU Sensor Parameters
ParameterH30
 AccelerometerGyroscopeMagnetometer
Range±16g±2000°/s±49Gauss
Bias Instability0.035mg4°/h/
Bias Stability/
Random Walk/
Nonlinearity±0.5%FS±0.05%FS±0.2%FS
Bandwidth (-3dB)42Hz49Hz/
Zero Offset Temperature Drift±20mg±1°/s/
Navigation Performance Parameters
ParameterH30
Roll Angle Accuracy0.1°
Roll Angle Range±180°
Pitch Angle Accuracy0.1°
Pitch Angle Range±90°
Reference-Free Heading Accuracy0.5°
Reference-Free Heading Range±180°
Magnetically Referenced Heading Accuracy1°
Magnetically Referenced Heading Range±180°
Angle Resolution0.01°
Hardware Overview
Certification
HSCODE/
USHSCODE/
UPC
EUHSCODE/
COOCHINA
H30WPx1
USB-Cx1
Aviation Connector Cablex1
Serial Adapter Boardx1
WHEELTEC H30WP 9-Axis IMU, Gyroscope 9-Axis Attitude Sensor Accelerometer Magnetometer, ROS2
SKU 100026335
The WHEELTEC H30WP is a high-precision attitude sensor designed to accurately measure key data of carriers, including 3D attitude angles, acceleration, angular velocity, and magnetic field strength. Engineered with industrial-grade reliability, this sensor integrates a 3-axis MEMS gyroscope, a 3-axis MEMS accelerometer, and a 3-axis magnetic sensor—delivering robust performance for professional applications.
USD$100.00
You may also add
