400Hz Max Data Output: Up to 400Hz raw sensor data (default 200Hz, customizable).
| Parameter | H30 | |
| Model | H30 MINI | H30WP |
| Dimensions | 24.5*24.5*14.5mm | 63*55*24.5mm |
| Housing | Ultra-compact metal case | Standard metal case |
| Output Interface | Type-C/SH1.0 6PIN | Aviation waterproof connector |
| Power Consumption | 186mW | 210mW |
| Reserved Interface | UART | UART/RS485 |
| Input Voltage | 4.5–5.2V DC | 5–26V |
| Axis Count | 9-axis (all models) | |
| Operating Temperature | -40°C–85°C (all models) | |
| Command Configuration | Supports serial command configuration: calibration, setup, mode switching, etc. (all models) | |
| IMU Data Output Max Rate | 400Hz | |
| Parameter | H30 | |||
| Accelerometer | Gyroscope | Magnetometer | ||
| Range | ±16g | ±2000°/s | ±49Gauss | |
| Bias Instability | 0.035mg | 4°/h | / | |
| Bias Stability | / | |||
| Random Walk | / | |||
| Nonlinearity | ±0.5%FS | ±0.05%FS | ±0.2%FS | |
| Bandwidth (-3dB) | 42Hz | 49Hz | / | |
| Zero Offset Temperature Drift | ±20mg | ±1°/s | / | |
| Parameter | H30 |
| Roll Angle Accuracy | 0.1° |
| Roll Angle Range | ±180° |
| Pitch Angle Accuracy | 0.1° |
| Pitch Angle Range | ±90° |
| Reference-Free Heading Accuracy | 0.5° |
| Reference-Free Heading Range | ±180° |
| Magnetically Referenced Heading Accuracy | 1° |
| Magnetically Referenced Heading Range | ±180° |
| Angle Resolution | 0.01° |
| Pitch/Roll (Static) | / |
| Pitch/Roll (Dynamic) | |
| Heading Drift (Static, 6DOF) | |
| Heading Drift (Dynamic, 6DOF) | |
| Heading (Magnetic-Assisted, AHRS) | |
| Heading Rotation Error (6DOF) |
| HSCODE | / |
| USHSCODE | / |
| UPC | |
| EUHSCODE | / |
| COO | CHINA |
| H30Mini | x1 |
| USB-C Cable | x1 |
| SH1.0 6PIN Cable | x1 |
The WHEELTEC H30 MINI is a high-precision attitude sensor designed to accurately measure key data of carriers, including 3D attitude angles, acceleration, angular velocity, and magnetic field strength. Engineered with industrial-grade reliability, this sensor integrates a 3-axis MEMS gyroscope, a 3-axis MEMS accelerometer, and a 3-axis magnetic sensor—delivering robust performance for professional applications.
