seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      L3D Cube (8x8x8 Full Color Kit)
      SKU 110990460
      $399.00
      5 Available
      $399.00/1pcs+
      $359.10/10pcs+
      $339.15/20pcs+
      $319.20/50pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      The L3D Cube is a 3D LED display that will blow your MIND! 512 RGB LEDs in a 8x8x8 array. Works out of the box. 100% open-source. Programmable over your home's wifi. Built-in microphone for INSANE music visualizations. This is the top selling 8x8x8 3D LED Cube kit in the world with an ever-expanding collection of 3D LED Cube apps at CubeTube.org.
      L3D Cube: Your First Volumetric Display  from  Looking Glass  on  Vimeo.
      • The L3D Cube is a full color 8x8x8 LED cube that shows brilliant images and animations in 3D.
      • Easier to assemble than an Ikea shelf!  Takes just 30 minutes, no soldering required.
      • No programming required to get started -- just assemble and plug it in. Comes preloaded with our most popular visualizations.
      • Once you're ready to start programming on the Cube, make new 3D apps in minutes using Processing or Arduino (a.k.a.Wiring).
      • Create and share your own 3D Cube apps online at CubeTube.org with a click of a button.
      • All of the hardware & software is completely open source under a Creative Commons Attribution-Sharealike 2.5 license.
      • Power: 5V 1A USB power can handle most applications on your Cube - so, this sucker can run off your computer, wall wart, or a battery pack. For super intense visualizations, we've also included a 2A adapter. 100VAC - 220VAC input (you will need to supply your own prong adapter if outside the US)
      • 512 WS2812B RGB LEDs, 100% tested.  We ship with a replacement reed of 8 LEDs, just in case.
      • Comes with a Spark Photon for instant WiFi connectivity and blazing processor speeds.
      • Arduino-compatiable -- includes headers for adding your favorite Arduino.
      • Laser-cut acrylic housing.
      • Built-in microphone and 3-axis accelerometer.
      • Assembly instructions here.
      • Product Weight: 1089.0 grams
      • Product Dimensions: 25cm x 22cm x 7cm
      Five ways to use your L3D Cube
      • Plug it in, no setup!  A standard set of visualizations will automatically start playing when you first plug in your cube.  *NEW:  you can control the visualizations by tilting your cube, thanks to the included accelerometer!
      • Download new applications from CubeTube wirelessly to your cube with the click of a button.
      • Write your own programs for the Cube in Arduino language or Processing.  The programs can be stored in the cube's memory or can be streamed to your cube from a computer over your WiFi network.  Here's the definitive guide to programming in 3D in a cube.
      • Connect together multiple cubes and make them interact.
      • Hack it!  Add your own sensors for new interactions or make improvements to your cube itself.  Everything (hardware+software) is open-source and fully documented so hacking is fun!
      Documents
      Technical Details
      Dimensions250mm x 200mm x 70mm
      WeightG.W 1095g
      BatteryExclude
      Reviews
      Questions and Answers
      SUBMIT
      0
      How many visualizations are preloaded?
      on Jan 15,2018
      Replyupvote ()
      Hi Dear Customer, please refer to http://cubetube.org/viz/133/. thanks.
      on Jan 17,2018 17:02 PM
      Replyupvote ()
      The 8x8x8 L3D Cubes come pre-loaded with four demos:Demo 1. FireworksDemo 2. ZplasmaDemo 3. SquarralDemo 4. FFTJoy (sound reactive)
      on Jan 17,2018 17:06 PM
      Replyupvote ()
      Reply
      0
      The USB connector got detached from the board. Where can I purchase a new board?
      on Jun 14,2018
      Replyupvote ()
      Hi,there-please try to fix it youself(it is not a big problem), if it has no works, buy a new one, we don't sell it alone,Sorry. Regards!
      on Jun 15,2018 11:32 AM
      Replyupvote ()
      Reply
      0
      Hi, I wonder where you ship from and approx. how long it would take to ship on to Japan? Thx!
      on May 09,2018
      Replyupvote ()
      It ships from Hongkong , it takes 2-3 working days via DHL
      on May 11,2018 09:40 AM
      Replyupvote ()
      Reply
      0
      I have an L3D Cube with a cracked plastic case. How do I get a new case?
      on Mar 22,2018
      Replyupvote ()
      Hi there~Please email us with more detail, such as the order number and some pictures will be helpful. Regards===============================================================order@seeed.cc
      on Mar 22,2018 17:56 PM
      Replyupvote ()
      Reply
      0
      i have a l3d with a bad board. can i get a new board?
      on Feb 07,2018
      Replyupvote ()
      Hi there~ Please email our After-sales service team ### techsupport@seeed.cc ###.Please offer more detail, some pictures or vedio will be helpful. Regards
      on Feb 07,2018 14:19 PM
      Replyupvote ()
      Reply
      0
      hi, sent to Italy? Rome?
      on Jan 20,2018
      Replyupvote ()
      Yes,sure . we support delivery to Italy Rome.
      on Jan 25,2018 14:05 PM
      Replyupvote ()
      Reply
      0
      How do I connect the USB wire to the port to program it ? the port is inside the casing and I cant find out how to open the case and I cant find any guide either :(
      on Jun 21,2017
      Replyupvote ()
      HI Dear Customer, this is the assembly process and you can reverse it. https://www.dropbox.com/sh/tyudi407wq55rf2/AADVB_WFlFF6lbwUJyrFKErga?dl=0&preview=l3dcube_instructions_A5booklet_v9_poster_OUTLINED.pdf for more info, please refer to http://cubetube.org/docs/. thanks, Bill
      on Jan 17,2018 17:11 PM
      Replyupvote ()
      Reply
        View History
        SKU 110990460
        $399.00
        5 Available
        Maximum Qty: 5
        $399.00/1pcs+
        $359.10/10pcs+
        $339.15/20pcs+
        $319.20/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
