the AI Hardware Partner
Toggle Nav
Loading...
LTE Cat 1 Pi HAT (Europe)
LTE CAT 1 Pi HAT is an open-source cellular extension modem for Raspberry Pi, based on u-blox LARA-R2xx series. It is compatible with Raspberry Pi 1 Model B+ and up to Raspberry Pi 4.
$69.00
Out of stock
  • 10+: $65.00
Also Add: $0.00
This USA version of the LTE CAT 1 Pi HAT is designed for LTE Category 1 networks with 2G fallback, embedding common protocols, like TCP/UDP, HTTP.
LTE CAT 1 Pi HAT support UART and USB interfaces. Raspberry Pi can communicate with LTE CAT 1 Pi HAT via UART using AT commands without the need of any special driver.
This Pi HAT is well suited for rapid prototype building.
  • Compatible with Raspberry Pi 1 Model B+ and up to Raspberry Pi 4
  • Can communicate using UART and USB interfaces
  • Includes I2C and Digital Grove connectors to connect Grove modules
  • Access to both IPV4/IPV6 with dual stack capabilities
  • Wide range of embedded protocols such as TCP, UDP, HTTP, FTP, SSL
  • Supports AT commands with 3GPP TS 27.007 [8], TS 27.005 [9] standards
Applications
  • IoT gateway
  • Data logger
  • Vending machine
  • POS
  • Smart home devices
  • Robot
  • Advertising
  • Other scenario need cellular networks
Dimensions 65mm x56mm x18.5mm
Weight G.W 54g
Battery Exclude
LTE Cat 1 Pi HAT (Europe) 1
LTE Antenna 2
HSCODE 8517709000
USHSCODE 8517180050
UPC 841454120865
EUHSCODE 8517180000
COO CHINA
RoHS 1
