LTE Cat 1 Pi HAT (USA - VZW)
SKU 113990454
69.00
19 Available
$69.00/ 1pcs+
$66.00/ 10pcs+
Seeed’s LTE CAT.1 Pi HAT is an open source cellular extension modem for Raspberry Pi, based on u-blox LARA-R2xx series. It compatible with Raspberry Pi 1 Model B+ and later versions.
LTE CAT.1 Pi HAT is designed for LTE Category 1 networks and with 2G fallback(EU version only). Embedding common protocols, like TCP/UDP, HTTP.
LTE CAT.1 Pi HAT support UART and USB interfaces. By UART, Raspberry Pi communicate with LTE CAT.1 Pi HAT via AT command without any special driver. It’s well suited for building prototyping rapidly.
  • Compatible with Raspberry Pi 1 Model B+ and later versions
  • LTE CAT.1 and support 2G fallback(EU version only)
  • UART and USB interface for communicate
  • Support Grove I2C and Digital connector
  • Protocols on cellular module
  • Embed TCP/UDP stack
  • Embed HTTP, FTP, SSL
  • Dual stack IPV4/IPV6
  • 3GPP TS 27.007 [8], TS 27.005 [9] standard AT command
Applications
  • IoT gateway
  • Data logger
  • Vending machine
  • POS
  • Smart home devices
  • Robot
  • Advertising
  • Other scenario need cellular networks
Technical Details
Dimensions65mm x 56mm x 18.50mm
WeightG.W 53.90g     N.W 23.40g
BatteryExclude
LTE Cat 1 Pi HAT (USA - VZW)1
LTE Antenna2
ECCN5A991.b
HSCODE8517709000
Reviews
Questions and Answers
SUBMIT
0
How easy is it to control it from software? Nodejs, python libraries? AT commands? Code examples?
on Aug 27,2018
Reply upvote ()
Hi there, We have python library and AT commands as well. Here is the python library. https://github.com/Seeed-Studio/ublox_lara_r2_pi_hat Here is the AT command. https://github.com/SeeedDocument/LTE_Cat_1_Pi_HAT/raw/master/res/u-blox-CEL_ATCommands_(UBX-13002752).pdf thanks.
on Aug 28,2018 14:34 PM
Reply upvote ()
Reply
0
Is there or will there be a version for Australia i.e fitted with UBLOX LARA-R280?
on Jul 19,2018
Reply upvote ()
Hi there, Sorry, We do not have a plan this moment. thanks.
on Aug 28,2018 14:32 PM
Reply upvote ()
Reply
0
Is this in-carrier certified?
on Jul 16,2018
Reply upvote ()
Hi, there~we are trying to apply it, Regards!
on Jul 23,2018 18:05 PM
Reply upvote ()
Reply
    View History
    SKU 113990454
    $69.00
    19 Available
    $69.00/ 1pcs+
    $66.00/ 10pcs+
    • Related
    • Description
    • Technical Details
    • Learn
    • Reviews
    • Questions and Answers
    SUBMIT
