seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Mesh Bee - Open Source Zigbee Pro Module with MCU (JN5168)
      SKU 114990002
      $19.90
      2 Available
      $19.90/1pcs+
      $17.91/10pcs+
      $16.91/20pcs+
      $15.92/50pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      Mesh Bee is a 2.4GHz wireless transceiver from seeed studio. It's based on NXP's newly JN516x series wireless microcontroller chip and supports ZigBee Pro network stack. The factory firmware wraps the complicated ZigBee stack operation into a few easy to use serial commands, and drives Mesh Bee into a transparent serial communication node that can be part of a simple point-to-point connection or a complex mesh network. Moreover, Mesh Bee is totally open hardware and open sourced, which means that you can customize the firmware on your requirements. You can use JN516x's ARM core to control things and JenOS to simplify your development. The development environment and tools from NXP are all free. Mesh Bee will bring you lots of fun.
      Feature:
      • Range: Indoor/Urban: up to 30m; Outdoor line-of-sight: up to 100m;
      • Receiver Sensitivity: -95dBm
      • Data Transmission Rate: 4800, 9600, 19200, 38400, 57600, 115200 (bps)
      • Working Frequency: unlicensed 2.4GHz band
      • Communication type: Point to Point or Start Network or Mesh Network
      • OTA support: update node's firmware on-the-air
      • Easy-to-Use Serial Interface and rich extendable ports
      • Easy-to-Use AT Command: Setup ZigBee network, Set Serial Baud Rate, etc.
      • Open source Hardware and Firmware
      • Programmable 32-bit RISC CPU: 32M clock, 256KB Flash, 32KB RAM, 4KB EEPROM
      • Socket compatible with the Xbee, so you can plug it into any Xbee socket as a quick replacement.
      Note: Mesh Bee will not communicate with Xbee as the ZigBee stack versions they're using are different.
      • Microprocessor :JN5168 (32-bit RISC CPU, 32MHz clock speed)
      • Resources :256kB/32kB/4kB (Flash/RAM/EEPROM)
      • PCB size :24.5mmx30.5mmx0.8mm
      • Outline Dimension :24.5mmx30.5mmx9.77mm
      • Indicators :No
      • Power supply :3.3V
      • IO counts :12
      • ADC input :3(2 multiplexing with IO)
      • Interfaces :UARTx2, SPI, I2C
      • Program interface :UART+MISO
      • Connectivity :Socket compatible with XBee
      • Communication Protocol :Uart(TTL)
      • Operating Frequency Band :2.4GHz
      • Stack/Software :RF4CE, JenNet-IP , ZigBee Pro
      Application
      Technical Details
      Dimensions40mm x 40mm x 11mm
      WeightG.W 3.5g
      BatteryExclude
      Mesh Bee1
      Reviews
      Questions and Answers
      SUBMIT
      0
      How can we program the JN5168 if we need to implement some code /application inside it? What tools do we require?
      on Mar 06,2017
      Replyupvote ()
      1.You can develop a stand-alone application in AUPS. The user application consists of two arduino-style functions at the top level: setup & loop, which act just like arduino's.2.NXP provides full-scale development environment, tools and documents. The development environment consists of the SDK toolchain and the ZigBee stack SDK.
      on Jan 08,2018 17:46 PM
      Replyupvote ()
      Reply
      0
      can the board be used for Nxp 5168 development? are headers provided?
      on Oct 19,2016
      Replyupvote ()
      The microprocessor is NXP JN5168 (32-bit RISC CPU, 32MHz clock speed)
      on Jan 08,2018 18:15 PM
      Replyupvote ()
      Reply
      0
      Are these really ARM Core architecture? Which one? Cortex-M?
      on Oct 19,2016
      Replyupvote ()
      IN FACT IT IS A 32-bit RISC CPU
      on Jan 08,2018 18:09 PM
      Replyupvote ()
      Reply
      0
      Hello, Is it possible"XBee Pro PCB Antenna - S1"work together"Mesh Bee - Open Source Zigbee Pro Module with MCU (JN5168)"with mesh?
      on Oct 19,2016
      Replyupvote ()
      hi , I am sorry to inform you that Mesh Bee will not communicate with Xbee as the ZigBee stack versions they're using are different.
      on Jan 08,2018 18:13 PM
      Replyupvote ()
      Reply
        View History
        SKU 114990002
        $19.90
        2 Available
        Maximum Qty: 5
        $19.90/1pcs+
        $17.91/10pcs+
        $16.91/20pcs+
        $15.92/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
