Product Details
Wiki & Learn
Reviews
Download PDF
Feature
- **Active Stereo IR** Employs active stereo IR technology for depth output, enabling accurate and reliable data output in various lighting conditions
- **Wide Sensing Range** Provides quality depth data output from 0.1m to 20m
- **Wide FOV** Provides wide field of view data at 9-degree horizontal and 65-degree vertical
- **Multi-camera synchrnoization** Supports multi-camera synchronization for both depth image and RGB image
- **USB Connection** Uses single USB 3.0 Type-C cable for power and connectivity
Overall Specifications
Category
Details
Basic Parameters
Operating Environment
Full scene: Indoor & Outdoor
Depth Parameters
Max Working Range [1]
0.10 - 20m+
Recommended Range
0.26 - 3m
IMU
Supported
UVC Camera
Supported
SDK
Orbbec SDK
Depth Technology
Stereo Vision
Baseline
50 mm
Spatial Relative Accuracy [2]
≤1.5% (1280 × 800 @ 2m & 90% × 90% ROI)
Field of View (FoV)
90° × 65° @ 2m (1280 × 800)
Resolution@Frame Rate
Up to: 1280 × 800 @ 30fps
Shutter Type
Global Shutter
Color Parameters
Field of View (FoV)
86° × 55°
Up to: 1920 × 1080 @ 30fps
Image Format
YUYV & MJPEG
Shutter Type
Rolling Shutter
Electrical Parameters
Power Supply Recommendation
DC 5V & ≥1.5A
Average Power Consumption
<3 W
Filter Cover
Yes, IR Pass
Physical Parameters
Operating Temperature
-10 - 45℃
IP Rating
IP5X
Dimensions
90 mm × 25 mm × 30.7 mm
Weight
99g
Data & Power Port
USB 3.0 & USB 2.0 Type-C
Multi-device Sync Port
8-pin Interface
Mounting Method
Bottom Mount: 1 × 1/4 - 20unc Threaded HoleBack Mount: 2 × M3 Threaded Holes
Hardware Overview
Application
  • Autonomous Mobile Robots
Targeted enhancement of depth imagingquality in reflective areas of high-gloss floorpaint or tiled floors under indoor incandescentlighting, as well as in shadowed areas of highdynamic range scenes with sunlight exposure.
  • Retail Shelf Robots
Targeted enhancement of depth imagingquality in shadowed areas of high dynamicrange scenes with sunlight exposure
  • Outdoor Delivery Robots
Targeted enhancement of depth imagingquality under strong outdoor lighting.
Certification
HSCODE8525891900
USHSCODE8525895050
UPC
EUHSCODE8517600000
COOCHINA
Orbbec Gemini 336 Depth Camera
x1
USB Type-A to Type-C
x1
Camera Mount
x1
SKU 100000774
The Gemini 336 is a brand-new addition to the Gemini 330 series. Building on the exceptional depth performance of the Gemini 335, it enhances active infrared imaging by filtering visible light. Specifically optimized for depth imaging quality in indoor reflective areas, dark regions of high-dynamic-range (HDR) scenarios, and outdoor strong light conditions, it delivers stable, high-quality depth data for users.
USD$310.00
