Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Supports 2.4G/5GHz dual-band
  • Wireless PHY rate can reach up to 1201Mbps
  • IEEE Standards: IEEE 802.11a/b/g/n/ac/ax
  • Dual Mode Bluetooth support : Simultaneous LE and BR / EDR
  • Form factor: M.2 Type 2230 S2 Key A+E Card
  • Connect to external antenna through MHF4/IPEX4 connectors
Chipset
RTL8852BE - CG
WLAN Standards
BT Specification
Bluetooth Core Specification v5.2/4.2/2.1
Host Interface
PCI Express 1.1 for WLAN & USB2.0 FS for Bluetooth
Antenna
Connect to the external antennas through MHF4 connector (Two antennas)
Dimension
M.2 Type 2230
Pluggable Card: 30*22*2.15mm (L*W*H)
Power Supply
DC 3.3V±0.2V @ 1.5A (Max)
Operation Temperature
-20°C to +70°C
Operation Humidity
10% to 95% RH (Non - Condensing)
Hardware Overview
Application
  • Edge AI Box & Mini PC: Supports Linux and Windows. Featuring a universal interface, it is widely integrated into various Edge AI Box.
  • Robotics & Embodied AI: Provides the low-latency, high-reliability wireless link and Bluetooth 5.2 connectivity essential for commercial service robot and AGV/AMR.
  • Industrial IoT: Ideal for harsh industrial environments where wired networking is impractical. It leverages Wi-Fi 6 for high-capacity data collection and transmission, with wide-temperature support making it highly popular in industrial application.
  • Consumer Electronics: Frequently used as a Wi-Fi 6 upgrade from legacy Wi-Fi 5 cards, significantly boosting the wireless networking performance of Laptop and PC.
Documents
Certification
HSCODE8517799000
USHSCODE8517690000
UPC
EUHSCODE8517180000
COOCHINA
Wireless RTL8852BE-CG
x1
RTL8852BE Wireless NIC, 2.4G/5GHz Dual-Band WiFi 6, Bluetooth 5.2, Compatible with Jetson Orin
SKU 100042928
The RTL8852BE is a compact Dual-band WLAN+Bluetooth Combo M.2 Card that integrates a 2T2R Dual-band WLAN subsystem with PCI Express controllers and a Bluetooth v5.2 subsystem with USB support. Compatible with IEEE 802.11 a/b/g/n/ac/ax standards, it delivers a maximum PHY rate of up to 1201 Mbps. Ideal for high-performance wireless and Bluetooth connectivity for using with embedded devices such as reComputer J4012.
USD$13.50
