seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Raspberry Pi B+&2 Acrylic Enclosure w& CPU Fan
      SKU 114990129
      $7.95
      6 Available
      $7.95/1pcs+
      $7.16/10pcs+
      $6.76/20pcs+
      $6.36/50pcs+
      ADD TO CART
      Introduction:
      It is a good plastic box for Raspberry Pi, which can protect it with one of these snazzy plastic enclosures?. These cases protect the Raspberry Pi from things like rogue wires that might short it out while still allowing full access to the board! Simply snap the RPi into the bottom half of the enclosure, then snap the two sides together.
      The enclosure provides slots to access the peripheral header, USB ports, Ethernet, SD card, HMDI, composite video, audio, CSI and JTAG connectors as well as feet and vents to ensure the board gets proper cooling and plus-shaped wall mounting slots. All of the status LEDs on the Pi are visible through the case thanks to light pipes embedded in the design. This is a really slick case and once you've gotten your hands on a Raspberry Pi, you'll want to snag one of these to put it in!
      Features:
      3mm acrylic
      Light and easy to transport
      good heat dispersion
      Compatible with Raspberry PiB+/2.
      Specification:
      Case size: 95x65.5x34.5mm
      Fan size: 30x30x7mm
      M3 screw x 4
      M3 nut x 4
      Technical Details
      Dimensions80mm x 120mm x 19.5mm
      WeightG.W 76g
      BatteryExclude
      Reviews
      Questions and Answers
      SUBMIT
      0
      The Fan size is it compatible with Raspberry Pi 3 model B ????
      on Nov 28,2017
      Replyupvote ()
      Hi there~ It is compatible with Raspberry Pi 3 model B.Regards
      on Nov 29,2017 17:17 PM
      Replyupvote ()
      Reply
        View History
        SKU 114990129
        $7.95
        6 Available
        ADD TO CART
        $7.95/1pcs+
        $7.16/10pcs+
        $6.76/20pcs+
        $6.36/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
