the AI Hardware Partner
Toggle Nav
Loading...
Arduino Adapter For Raspberry Pi
Arduino is a massive ecosystem, if there's a way for the Raspberry Pi GPIO interface to adapt to Arduino pinouts, it is possible to use the Pi together with vast Arduino shields and hardware/software resources
$30.00
Out of stock
  • 10+: $27.00
Arduino is a massive ecosystem, if there's a way for the Raspberry Pi GPIO interface to adapt to Arduino pinouts, it is possible to use the Pi together with vast Arduino shields and hardware/software resources. The ARPI600 is just intended for this.
What's more, the ARPI600 also support XBee modules, make it easy to add wireless feature to your great project.
Supported Pi:
Raspberry Pi 1 Model A+
Raspberry Pi 1 Model B+
Raspberry Pi 2 Model B
FEATURES
  • Compatible with Arduino UNO, Leonardo, easy to connect with various Arduino shields
  • XBee connector for connecting various XBee modules
  • Sensor interface for connecting various sensors
  • Onboard USB TO UART for serial port debugging, also can be configured as XBee USB adapter
  • Onboard ADC, 10 bit, 38KSPS, 11 channels (6 channels for Arduino interface, 5 channels for sensors)
  • Onboard RTC
SPECIFICATION
1.Arduino connector : for connecting Arduino shields
2.ICSP interface : Arduino ICSP
3.XBee connector : for connecting XBee communication modules
4.Sensor interface : for connecting sensors
5.Raspberry Pi connector : for connecting Raspberry Pi
6.USB TO UART
7.TLC1543 : AD converter
8.PCF8563 : RTC
9.CP2102
10.32.768KHz crystal : for RTC
11.Power indicator
12.XBee state LED
13.XBee and Arduino interface RESET button
14.XBee EASYLINK button
15.RTC battery holder : for CR1220 button battery
16.TLC1543 reference voltage configuration jumper
17.RTC jumper
18.UART jumper
when connecting P_RX and CP_TX, P_TX and CP_RX respectively, USB TO UART is connected to Raspberry Pi serial port
when connecting XB_RX and CP_TX, XB_TX and CP_RX respectively, USB TO UART is connected to XBee serial port
when connecting XB_RX and P_TX, XB_TX and P_RX respectively, Raspberry Pi serial port is connected to XBee serial port
19.Arduino AD selection jumper
short 2 and 3 : Arduino A0-A5 as AD input
short 1 and 2 : Arduino A0-A5 as digital control
20.Arduino I2C selection jumper
short the jumper : Arduino A4-A5 as I2C control (the A4-A5 of Arduino AD selection jumper should be opened)
21.Arduino SPI selection jumper
short 1 and 2 : Arduino D11-D13 as SPI control (default)
short 2 and 3 : Arduino D11-D13 as digital control
DOCUMENTS
Please visit wiki page for more info about this product.
For technical support, please post your questions to our forum
Dimensions 150mm x105mm x29mm
Weight G.W 101g
Battery Exclude
HSCODE 8473309000
USHSCODE 8471410150
UPC 841454112099
EUHSCODE 8471707000
COO CHINA
RoHS 1
