Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Proven EFR32MG21 Chip
Trusted by millions of users, the EFR32MG21 chip ensures reliable and stable performance.
  • Compact Size
65% smaller than the ZBDongle-E, making it more flexible to fit into various USB ports.
  • Wide Platform Compatibility
Works seamlessly with multiple open-source platforms such as Home Assistant, Zigbee2MQTT and openHAB to meet diverse user needs.
  • Easy Firmware Flashin
Supports firmware flashing via the SONOFF Dongle Flasher tool, allowing you to switch between different operating modes effortlessly.
  • Includes USB Extension Cable
Enables flexible placement and minimizes electromagnetic interference from USB 3.0 ports.
ProductSONOFF Dongle Lite MG21 Zigbee/Thread USB Dongle
ModelDongle-LMG21
ConnectionUSB ports
Antenna Gain2dBi
Number of Antennas1
SocEFR32MG21
Supported PlatformsHome Assistant / OpenHAB /Zigbee2MQTT/iobroker
Cable IncludedUSB port cable (0.5m)
Input5V⎓500mA
ZigbeeIEEE 802.15.4
Working temperature-10°C~60°
Casing materialsAluminum, PC+ABS
ColorDim gray
Application
  • Designed as a compact Zigbee USB coordinator for open-source platforms including Home Assistant, Zigbee2MQTT, and openHAB
  • Ideal for entry-level and small-to-medium smart home setups requiring local control of Zigbee devices
  • Can be flashed as Zigbee Coordinator, Zigbee Router, OpenThread RCP, or MultiPAN RCP for flexible roles (including Matter over Thread support)
  • Suitable for space-constrained installations thanks to its compact size (65% smaller than ZBDongle-E) and included USB extension cable
Certification
HSCODE8517629990
USHSCODE8517620010
UPC
EUHSCODE8517180000
COOCHINA
SONOFF Dongle Lite MG21 Zigbee/Thread USB Donglex1
USB cable extension (0.5m)x1
Packaging boxx1
Quick guidex1
SKU 100017991
SONOFF Dongle Lite MG21 is a versatile Zigbee USB coordinator powered by the stable and reliable EFR32MG21 chip, model Dongle-LMG21. It can be used as a Zigbee gateway in Home Assistant, openHAB, Zigbee2MQTT, or other open-source platforms to control all your Zigbee devices locally.
Additionally, it can easily be flashed with Zigbee Router, OpenThread RCP, or MultiPAN RCP firmware through the SONOFF Dongle Flasher, playing different roles in the smart home.
USD$24.90
