Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Note:
This 101991470, Seeed Studio XIAO ESP32-C6 (Tape & Reel) is specifically designed for Surface Mount Technology (SMT) production. This variant comes in a Tape & Reel package for seamless integration into automated assembly lines and does not include pin headers.
  • Enhanced Connectivity: Combines 2.4GHz Wi-Fi 6 (802.11ax), Bluetooth 5(LE), and IEEE 802.15.4 radio connectivity, allowing you to apply the Thread and Zigbee protocols.
  • Matter Native: Supports building Matter-compliant smart home projects thanks to its enhanced connectivity, achieving interoperability
  • Security Encrypted on Chip: Powered by ESP32-C6 Wi-Fi 6 & BLE 5 & Thread/Zigbee SoC | Espressif Systems, it brings enhanced encrypted-on-chip security to your smart home projects via secure boot, encryption, and Trusted Execution Environment (TEE)
  • Outstanding RF performance: Has an on-board antenna with up to 80m BLE/Wi-Fi range, while reserving an interface for external UFL antenna
  • Leveraging Power Consumption: Comes with four working modes, with the lowest being 15 μA in deep sleep mode, while also supporting lithium battery charge management.
  • Dual RISC-V Processors: Incorporates two 32-bit RISC-V processors, with the high-performance processor running up to 160 MHz, and the low-power processor clocking up to 20 MHz
  • Classic XIAO Designs: Remains the classic XIAO designs of the thumb-size form factor of 21 x 17.8mm, and single-sided mount, making it perfect for space-limited projects such as wearables
  • Seamless integration with mainstream Cloud Platforms: ESP Rain Maker, AWS IoT, Microsoft Azure, and Google Cloud
Production-Ready Design with Fusion PCBA Support
Being the 8th member of the Seeed Studio XIAO, the smallest Arduino boards for tinyML, XIAO ESP32-C6 remains the classic XIAO design. All these features make it a perfect fit for either space-limited projects such as wearables, or a production-ready unit for your PCBA designs. Through our Turn Your XIAO Projects into Reality with Fusion: 30% Off PCBA - Latest News from Seeed Studio %, you can not only enjoy the lowest unit prices for all XIAO modules from our Fusion Open Parts Library, but also fabricate and scale your XIAO-based PCBA designs at low cost (30% off) with FREE Design for Manufacturing consulting services, streamlining your journey from prototype to production.
Note:
XIAO SoM User Manual open-sources all hardware and software materials of XIAO, providing professional product design guidelines to help you accelerate ideas off the ground, streamline product design, providing a seamless experience from module selection to mass production. You can check here to see more info.
Starter Kit with free Course for all Electronics Neophytes and Enthusiasts
Seeed Studio has provided the Seeed Studio XIAO Starter Kit - all Seeed Studio XIAO series Development boards supported, XIAO Series Expansion board, 9 Grove Modules, Additional Controllable Components, presented with XIAO Series Courses - Seeed Studio along with Seeed Studio XIAO Kit Courses | Seeed Studio Wiki for you quickly get started with microcontrollers and electronics, regarding all the Seeed Studio XIAO boards, promising you a great learning experience.
Not only programming but also electronics knowledge is not required, you will be taken step by step, from understanding the basic concepts to exercising the simple projects individually, finally being able to build complex, interesting, wearable projects on your own, owing a practical electronic product prototype from the course.
You can have access to the Grove Ecosystem Introduction | Seeed Studio Wiki by connecting it to the compatible Seeed Studio XIAO Expansion board for XIAO Series with Grove OLED - IIC, Uart, Analog/Digital - Seeed Studio. We have developed more than Grove, covering a wide range of applications that can fulfill various needs. For example, you can make a BLE AI-driven Smartwatch Detecting Potential Sun Damage - Hackster.io by connecting the Seeed Studio XIAO nRF52840 with an Seeed Studio XIAO Expansion board for XIAO Series with Grove OLED - IIC, Uart, Analog/Digital - Seeed Studio, and a Grove - UV Sensor - Seeed Studio. Get started and explore the infinite possibilities of the Seeed Studio XIAO series!
If you are interested in programming embedded machine learning, we have Seeed Studio Codecraft Graphical Programming Platform for TinyML visual programming that can help you quickly start your own TinyML project. And we have set up a #tinyml channel on our Discord server, please click to join for 24/7 making, sharing, discussing, and helping each other out.
Product
XIAO ESP32-C6(3PCS)
XIAO ESP32-C3(Tape&Reel)
XIAO ESP32-S3(Tape&Reel)
Processor
Espressif ESP32-C6 SoC
Espressif ESP32-C3 SoC
Espressif ESP32-S3R8 SoC
two 32-bit RISC-V processors, with the high-performance one running up to 160 MHz, and the low-power one clocking up to 20 MHz
RISC-V single-core 32-bit chip processor with a four-stage pipeline that operates at up to 160 MHz
Xtensa LX7 dual-core, 32-bit processor running up to 240 MHz
Wireless
Complete 2.4GHz Wi-Fi 6 subsystem
Complete 2.4GHz Wi-Fi subsystem
Bluetooth Low Energy 5.0
Zigbee,Thread,IEEE 802.15.4
On-chip Memory
512KB SRAM & 4MB Flash
400KB SRAM & 4MB Flash
8MB PSRAM & 8MB Flash
Interface
1x UART
1x LP_UART
1x IIC
1x LP_IIC
1x SPI
11x GPIO(PWM)
7x ADC
1xSDIO
1x UART
1x IIC
1x SPI
11x GPIO(PWM)
4x ADC
1x UART
1x IIC
1x SPI
11x GPIO(PWM)
9x ADC
1x User LED
1x Charge LED
1x Reset button
1x Boot button
Dimensions
21 x 17.8mm
Power
Input voltage (Type-C): 5V
Input voltage (BAT): 3.7V
Power Consumption Model(Typ.)
(Supply Power: 3.8V)
Modem-sleep Model: 30 mA
Light-sleep Model: 3.1 mA
Deep Sleep Model: 15 μA
Modem-sleep Model: 24 mA
Light-sleep Model: 3 mA
Deep Sleep Model: 44 μA
Modem-sleep Model: 27 mA
Light-sleep Model: 2 mA
Deep Sleep Model: 14 μA
Working Temperature
-40°C ~ 85°C
-40°C ~ 85°C
-40°C ~ 65°C
Hardware Overview
  • Onboard
  • PinOut
Application
Secure and Connected Smart Home, enhancing everyday life through automation, remote control, and more
Space-limited and Battery-Powered Wearables, thanks to their thumb-size and low-power consumption
Wireless IoT Scenarios, enabling rapid, reliable data transmission
Certification
HSCODE8543709990
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
Seeed Studio XIAO ESP32-C6(Tape&Reel)
×1
Seeed Studio XIAO ESP32-C6(Tape & Reel)
SKU 101991470
This is the Tape & Reel version of XIAO ESP32-C6, which is a cost-effective MCU based on Espressif’s ESP32-C6. This packaging format is designed for automated SMT assembly and large-scale production. This compact MCU excels in Matter-compliant smart home applications with its support for various wireless connectivity (2.4GHz Wi-Fi 6, BLE 5.0, Zigbee, and Thread). Designed with the thumb-size footprint and a single-sided mount of the XIAO Series, it's perfect for space-limited projects. Encrypted on the chip, the XIAO ESP32-C6 ensures a desired level of security, streamlined development experience, and swift market entry by integrating easily with major IoT Cloud platforms.
XIAO Dev Board
Pin Header
Package
USD$4.90
You may also add
