Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Dual-band: 150–960 MHz and 2.4 GHz on one module
The Wio-LR2021 module carries both bands, so one design can move between sub-GHz for long range and 2.4 GHz for worldwide, duty-cycle-free links. No second radio and no second board revision.
  • Fast bursts: FLRC up to 2.6 Mbps for images and audio
FLRC sends a payload in one short burst instead of trickling bytes, so a compressed image or a voice clip arrives in a moment rather than a minute. Drop to LoRa when range matters more.
  • Edge AI: ESP32-S3 with 8 MB PSRAM runs detection on board
The 8 MB PSRAM holds camera frames and model buffers, and the dual-core LX7 applies vector instructions to detection and recognition. Frames are judged locally, so the radio carries conclusions rather than raw pixels.
  • Camera and audio: a detachable media HAT is included
The HAT adds a 2 MP GC2145 camera, a MEMS microphone, an ES8311 codec, and an NS4150B amplifier with a speaker connector. It shares the main board footprint and links over a 14-pin FPC.
  • Field power interfaces: solar, Li-ion, and switchable peripheral rails
A 5 V solar input and a 3.7 V Li-ion connector feed a CN3165 charger that watches battery temperature. Camera, audio, OLED, and Grove rails can be switched off in software when a node is idle.
MCU ChipsetESP32-S3R8
ProcessorDual-core Xtensa LX7, 240 MHz
RAM512 KB SRAM, 8 MB PSRAM
Flash384 KB ROM
External Flash16 MB SPI NOR flash
Wi-Fi and Bluetooth2.4 GHz Wi-Fi 802.11 b/g/n, Bluetooth 5 LE
RF TransceiverSemtech LR2021, integrated in the Wio-LR2021 module
Frequency bands868-915 MHz @ Sub-GHz, 2400–2500 MHz @ 2.4 GHz
Maximum Transmit power+22 dBm @ Sub-GHz, +12 dBm @ 2.4GHz
Receiver Sensitivity-141.1dBm @ SubGHz, BW=125KHz, SF = 12
-133dBm @ 2.4GHz, BW=125KHz, SF = 12
Antenna2 × SMA (Wio-LR2021 Sub-GHz and 2.4 GHz)
3 × IPEX1 (Wio-LR2021 Sub-GHz and 2.4 GHz / ESP32-S3 2.4GHz)
Display128 × 64 monochrome OLED, CH1116
Power Inputs5 V USB Type-C
5 V Solar panel
3.7 V Li-ion battery
Power ConsumptionSleep mode: 76.3 uA
Total consumption (all RF functioning): 200.7 mA
InterfaceType-C USB;
Lithium battery connector (1.25 mm JST);
Solar panel connector (2.0 mm JST);
Grove connector;
DimensionsMain board: 55 × 38.5mm;
Media HAT: 55 × 38.5mm;
Hardware Overview
Diagram
Pinout
Note:
Since the main board uses a 16‑pin header while the Media Hat expansion board uses only a 14‑pin socket, careful attention must be paid to orientation during installation. Ensure that the pins are correctly ALIGNED. Incorrect installation may cause malfunction and could result in irreversible damage to the device.
Application
  • Remote Visual Inspection: Inspect towers, culverts, and substations without sending a crew. The node captures a frame, runs detection on the ESP32-S3, and returns a thumbnail over LoRa or a full image over FLRC at up to 2.6 Mbps. Best for utilities, telecom, and infrastructure teams.
  • Automated Meter Reading: Read water, gas, and electricity meters from a distance. The on-device model turns the camera image into digits, so only a few dozen bytes travel over LoRa. Best for utility metering and smart-city deployments.
  • Edge-Triggered Surveillance: Keep the radio quiet until something happens. When a person is detected, the node sends the key frame with a timestamp over the dual-band link, with no 4G plan and no mains power. Best for farms, construction sites, and remote facilities.
  • Off-Grid Asset and Environmental Monitoring: Track remote assets where there is no power and no network. Sensor data goes out over long-range LoRa, and a picture follows when a value looks wrong. Best for agriculture, pipelines, and environmental research.
Certification
HSCODE8543709990
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
Wio-LR2021 Dev Kit Main Boardx1
Wio-LR2021 Media HATx1
2.4GHz Stick Antennax1
868-915MHz Stick Antennax1
2.4GHz FPC Antennax1
16 Pin Headerx2
Speakerx1
Wio-LR2021 Dev Kit
SKU 100038329
The Wio‑LR2021 Dev Kit is a dual‑band LoRa development kit that pairs Semtech’s LR2021 transceiver with an ESP32‑S3 and a detachable media HAT. By bringing together sub‑GHz and 2.4 GHz connectivity, FLRC throughput of up to 2.6 Mbps, and on‑device AI on one board, it expands the scope of conventional LoRa applications and enables use cases that were previously unattainable.
USD$39.90
