Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
High Performance: The transmit power up to 22 dBm @470MHz,10dBm @ 433MHz; -136.5 dBm sensitivity for SF12 with 125 kHz BW.
Wireless Connectivity: SPI ADC & GPIOs , supports 433, 470MHz global LoRa & LoRaWAN frequency plan.
Small Size: 11.6mm X 11mm X 2.95mm@12 pins SMT.
Low Power Consumption: 1.62 uA sleep current.
Onboard RF Interface: default IPEX antenna port.
With over 10 years of ODM & OEM experience, our engineers and product experts are proficient in delivering customization and manufacturing services for hardware products. We are committed to assisting you at any moment and shortening your path from idea to product for emerging AIoT scenarios.
If you want to design in our Wio-E5/Wio-SX1262 Module, we provide a one-stop ODM and OEM service for quick customization and scale-up. Please contact [email protected] if you have a large quantity customization need.
If you have an interesting concept for any of Wio-E5/Wio-SX1262/Wio-LR1121/Wio-WM1110 and are willing to share it, we can help you make it a reality with Seeed Fusion’s one-stop-shop capabilities. Through our Fusion PCBA Sponsorship program, you can not only enjoy the lowest unit prices for Wio-E5/Wio-SX1262/Wio-LR1121/Wio-WM1110 modules from our Fusion Open Parts Library, but also fabricate and scale your PCBA designs at low cost (30% off) with FREE Design for Manufacturing consulting services, streamlining your journey from prototype to production. For more information, please click here.
Main Chip
SX1262-LF
Size
Package
18 pins, SMT
Frequency
Power Supply
3.3V @typical
Sleep Current
1.62uA (WDT on);
Maximum Operation Current (Transmitter)
55mA @10dBm in 433MHz
106mA @22dBm in 470MHz
Maximum Operation Current (Receiver)
6.3mA @BW125kHz, 434MHz type
6.3mA @BW125kHz, 470MHz type
Output Power
10dBm max @434MHz
22dBm max @470MHz
Receiver Sensitivity
@SF12, BW125kHz typical
-136dBm, @433MHz
-136.5dBm, @470MHz
Harmonics
<-31dBm above 1GHz
Antenna
IPEX port or SMT pin, default IPEX @50-ohm impedance
Interface
RF, SPI*1
Working Temperature
-40°C ~ 85°C
Units per Reel
1000pcs
Hardware Overview
Certification
HSCODE8517799000
USHSCODE8517790000
UPC
EUHSCODE8517180000
COOCHINA
Wio-SX1262-LF Wireless Module
x1
Wio-SX1262-LF LoRa Wireless Module (Tape Reel), SX1262 embeded, supports LoRa & LoRaWAN on 433 & 470
SKU 100097817
The Wio-SX1262-LF is a LoRa wireless module based on the Semtech SX1262 chip, supporting LoRa & LoRaWAN 433, 470 MHz frequency band. Equipped with an onboard IPEX antenna connector. Suitable for industrial, agricultural, smart home, and other long-range, low-power applications.
USD$4.39
You may also add
