Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Go from Module Selection to a Working Project
Discover how the Wio family supports your journey from early evaluation to real-world deployment, with setup guides, reference designs, SDKs, KiCad libraries, hands-on testing, and projects built by developers. Explore connectivity options across LoRa, Wi-Fi, BLE, GNSS, and more, then find the module and purchasing path that match your technical requirements, location, and development stage.
  • High Performance: The transmit power up to 33 dBm @868/930MHz; 11.23dBm @ 2.4-2.5GHz
  • Wireless Connectivity: SPI interface, supports Sub-GHz global LoRa&LoRaWAN frequency plan and 4GHz
  • Small Size: 17*12*2.6mm @24Pins SMT
  • Low Power Consumption: 35uA sleep current;Sub-GHz: [email protected]/3.3V; 2.4G:[email protected]/3.3V
  • RF Interface: With IPEX4 @1.5mm
  • FCC, CE, Certified
The Wio-LR1121 and Wio-E5 are both perfect choices for designing LoRa devices. Their main differences lie in whether you have a host MCU.
If you need a single MCU to complete your design, then the Wio-E5 is an excellent choice.
ODM & OEM
With over 10 years of ODM & OEM experience, our engineers and product experts are proficient in delivering customization and manufacturing services for hardware products. We are committed to assisting you at any moment and shortening your path from idea to product for emerging AIoT scenarios.
If you want to design in our Wio-E5/Wio-SX1262/Wio-LR1121 Module, we provide a one-stop ODM and OEM service for quick customization and scale-up. Please contact [email protected] if you have a large quantity customization need.
Seeed Fusion PCBA Services
With our Seeed Studio Fusion services, you can access competitive one-stop PCB fabrication, component sourcing, assembly, and testing, plus free DFA/DFM review to reduce manufacturing risks and accelerate the journey from prototype to production.
Main Chip
LR1121
Size
17*12*2.6 mm
Package
12 pins, SMT
Frequency
supports 863-928MHz; 2.4-2.5GHz
Power Supply
3.3V @typical
Sleep Current
1.35 μA
LR1121 Power Distribution Mode
DC-DC Mode
TCXO Supply Mode
By LR1121 VTCXO Pin
TCXO Supply Voltage
1.6~3.3 V
Maximum Operation Current
(Transmitter)
124.5mA @ LoRa® 915 TX 22dBm
31mA@ LoRa® 868 TX 14dBm
30.7mA@ LoRa® 2.4G TX 13dBm
(Receiver)
7.8mA@ LoRa® SF12 125kHz sub-GHz
6.7mA@ LoRa® SF12 125kHz 2.4GHz/S-band
Output Power
20.4dBm max @ LoRa®
11dBm max @ 2.4G
Receiver Sensitivity
RxBoost ON:
-126dBm @SubG,BW=125KHz, SF = 7
-140dBm @SubG, BW=125KHz, SF = 12
-118dBm @2.4G,BW=125KHz, SF = 7
-132.5dBm @2.4G ,BW=125KHz, SF = 7
RxBoost OFF:
-124dBm @SubG,BW=125KHz, SF = 7
-138dBm @SubG, BW=125KHz, SF = 12
Antenna
IPEX4 @1.5mm
Working Temperature
-40°C ~ 85°C
Hardware Overview
Certification
HSCODE8517799000
USHSCODE8517620090
UPC
EUHSCODE8517180000
COOCHINA
Wio-LR1121(with IPEX antenna connector)
x1
Wio-LR1121 Wireless LoRa Module with IPEX (Tape Reel), LR1121 embedded, supports sub-GHz, 2.4GHz ISM, and 2.1GHz satellite S-band
SKU 113991415
Wio-LR1121 is a multi-band LoRa® connectivity module designed for Internet of Things (IoT) LoRaWAN applications. It supports sub-GHz, 2.4GHz ISM, and 2.1GHz satellite S-band communications. The module features a compact size and an ultra-low power design, integrating a TCXO (temperature-compensated crystal oscillator) and an RF switch, is suitable for global use in smart homes, agricultural sensors, building automation, smart cities, asset tracking, retail store sensors, smart metering, and environmental monitoring.
USD$6.99
You may also add
