seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Wio Tracker - GPS, BT3.0, GSM, Arduino Compatible
      SKU 102990824
      $24.95
      50+ Available
      $24.00/10pcs+
      ADD TO CART
      “I like how easy it is to use with the Arduino IDE and Grove ecosystem.” – Lisa Li, Product Manager
      The Wio Tracker (Wireless Input Output) is an open source gateway based on the ARM Cortex-M0+ and Arduino M0 MCU which enable faster IoT GPS solutions. This Arduino and Grove compatible development board helps you track nearly any moving thing on the planet and then upload that data wirelessly. By integrating Bluetooth 3.0 and GPRS (an LTE solution is planned for release in Q3), the Wio Tracker allows for flexible communication solutions. While there are GPS/GPRS shields available for Arduino and other development boards, Seeed believes that having a single board solution is the best approach to your project.
      The Arduino and Grove compatibility allows for quicker development through numerous libraries and a supportive community. The GPS library which will be available with the board is not just limited to Arduino – it can function just as well if you chose to develop in C/C++. With 6 Grove connections available developers can plug in any combination of out 180+ sensors and actuators to make any project and solve any problem. Simplifying the prototyping and development phase is our goal.
      The Wio Tracker is well suited for outdoor projects where the device can connect to the GPS satellites and provide a real-time location of the item it is attached to. The GPRS provides a moderate bandwidth which allows immediate interaction between the user and device. Some example projects could be a bicycle sharing service, tracking pets or livestock, locating a vehicle, or even keeping track of a child.
      We mentioned earlier the Wio Tracker is a gateway to faster IoT solutions — and we meant it! Does your project need a few extra sensors, say a temperature sensor and maybe an accelerometer to tell the object's orientation? Our Grove sensors easily plug into our boards and allow you to quickly prototype and provide your project with a proof of concept. Next we can help you go from a prototype to an engineering sample, working with you to customize your own version of the Wio Tracker. Finally, if you decide to take your project to market we can help you with manufacturing, and even selling your product through our website and channels!
      From making a fun GPS based project at home, to manufacturing and selling a GPS product to consumers, Seeed is here to help you succeed.
      Key Features
      • Connects with GPS + BeiDou + QZSS – Allowing for Higher Precision Location Around the Globe
      • 99 Channels Allows for Quicker Lock Times
      • GLP Mode - 40% Power Consumption for Normal Mode
      • LOCUS Technology – Records Navigation Data Automatically
      • GPS, GSM, and BT Antennas Included
      • GSM AT Commands: GSM 07.07, 07.05 and enhanced AT Command
      • Bluetooth 3.0 with SPP Profile and HFP-AG Profile
      • 6 Grove Connectors (2x Digital, 2x Analog, 1x UART, 1 I2C)
      • Arduino IDE Compatibility
      • Small Form Factor (54.7mm x 48.2mm)
      • Nano SIM and microSD 2-in-1 Socket
      Hardware Overview
      Specifications
      Item
      Function
      Value
      Microcontroller
      Processor
      ATSAMD21G18A-MU
      ARM Cortex-M0+
      48MHZ
      Memory
      256K Bytes Flash
      32K Bytes SRAM
      GSM/GPRS
      GSM
      850/900/1800/1900MHz:
      Class 4 (2W @850/900MHz)
      Class 1 (1W @1800/1900MHz)
      AT Command:
      Low Power Consumption:
      1.2mA@DRX=5V
      GPRS
      GPRS Multi-slot Class 12:
      Down to 85.6kbps
      Up to 85.6kbps
      Protocol:
      TCP/UDP/FTP/HTTP/PPP/SSL
      SMS
      Peer to Peer Message
      SMS broadcast
      Text and PDU mode
      Audio
      Echo cancellation
      Noise elimination
      Bluetooth
      Bluetooth 3.0:
      SPP
      HFP-AG
      GNSS
      System
      GPS L1 1575.42MHz
      BeiDou B1 1561.10MHz
      Precision
      <2.5 m CEP (2.5m radius)
      Time To   First Lock
      EPOTM turns on
      Cold Start:<15s
      Warm Start:<5s
      Technology
      EASY/LOCUS/AlwaysLocate/EPO/GLP/AIC
      Peripheral
      Grove
      2 x Grove Digital Port
      2 x Analog Port
      1 x UART
      1 x I2C
      Antenna
      GSM Antenna
      Bluetooth Antenna
      GNSS Antenna
      Others
      USB: Power Supply/Firmware Upload
      JST 1.0 Battery Connector
      3.5mm Audio Jack (Mic and Sound)
      2 Buttons:
      GSM Power Button (MC20)
      Reset Button (M0)
      User RGB LED
      Speaker Interface
      Nano SIM and microSD 2 in 1 Socket
      Size
      Length
      54.7mm
      Width
      48.2mm
      Weight
      Board (No Battery): 45g
      Antennas: 9g
      Documents
      • For libraries and documents, please visit our Wiki  page.
      • For technical discussion, please come to our Forum.
      • For projects that you would like to share with the community, please visit Recipe.
      Additional Quotes from the Team
      • “I am excited to offer a development board with GPS, GPRS, and Bluetooth 3.0 solutions in such a small footprint.” – Ye Xiaobo, Product Manager.
      Technical Details
      Dimensions54.7mm x 48.2mm x 6mm
      WeightG.W 45g
      BatteryExclude
      Wio Tracker - GPS, BT3.0, GSM, Arduino Compatible1
      Reviews
      Questions and Answers
      SUBMIT
      0
      Is this GPRS for 2G, 3G, or 4G LTE?
      on Apr 27,2017
      Replyupvote ()
      Can you also offer external power option on the LTE model?
      on May 09,2017 10:12 AM
      Replyupvote ()
      It just for 2G(GSM/GPRS). The LTE version is coming soon.
      on Aug 24,2017 10:41 AM
      Replyupvote ()
      Wio GPS can power supply by two ways: one is usb cable, and charged battery in the same time; other is by battery.
      on Aug 24,2017 10:43 AM
      Replyupvote ()
      Reply
      0
      Can you share the full code for the application shown in the demo video?
      on Jun 06,2017
      Replyupvote ()
      Hi, here you are: https://github.com/SeeedDocument/Wio_GPS_Board/tree/master/Wild_adventure_tracker_demo
      on Aug 24,2017 11:04 AM
      Replyupvote ()
      Reply
      0
      Can one power the WIO tracker via USB-cable only?
      on Aug 01,2017
      Replyupvote ()
      It don&amp;#39;t work for you?
      on Aug 24,2017 10:38 AM
      Replyupvote ()
      Reply
      0
      Will battery be charged if WIO is connected to the power supply (via mini-USB)?
      on Jun 07,2017
      Replyupvote ()
      Yes, it will.
      Replyupvote ()
      Reply
      0
      is that 4G LTE version work in Europe?
      on Jun 02,2017
      Replyupvote ()
      Still under development. It should be coming soon.
      on Aug 24,2017 10:36 AM
      Replyupvote ()
      Reply
      1
      Does this unit have a low power sleep mode which will wake after x minutes?
      on Aug 08,2017
      Replyupvote ()
      I second this - what&amp;#39;s the minimal power consumption? That&amp;#39;s really the key question!
      on Aug 17,2017 08:56 AM
      Replyupvote ()
      Reply
      0
      Can be used as a GPS data logger? and What are the dimensions?
      on Jul 06,2017
      Replyupvote ()
      Yes, you can. Dimensions: 54.7mm x 48.2mm x 6mm
      on Aug 24,2017 10:33 AM
      Replyupvote ()
      Reply
        View History
        SKU 102990824
        $24.95
        50+ Available
        ADD TO CART
        $24.00/10pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
