Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
MeshCore is a multi platform system for enabling secure text based communications utilising LoRa radio hardware. It can be used for Off-Grid Communication, Emergency Response & Disaster Recovery, Outdoor Activities, Tactical Security including law enforcement, private security and also IoT sensor networks.
Wio Tracker L1 Pro for MeshCore comes with pre-flashed MeshCore Bluetooth Companion firmware. If you want to buy L1 Pro with pre-flashed Meshtastic firmware, please click here to buy.
      • Ready-to-Use Durable Enclosure
The L1 Pro comes with a rugged, lightweight enclosure designed for immediate use—no additional assembly required. Whether handheld or clipped onto gear, it’s built for adventure in any environment.
      • Pre-flashed with MeshCore firmware
Ready to use out of the box with pre-installed MeshCore Bluetooth Companion firmware for seamless setup.
      • Triple Power Supply Options
Equipped with a built-in 2000 mAh battery, Type-C fast charging, and solar input support, enabling flexible deployment in diverse environments—perfect for outdoor and mobile use.
Processor
Nordic nRF52840ARM® Cortex®-M4 with FPU runs up to 64 MHz
On-chip Memory
1 MB flash and 256 kB RAM
Wireless
LoRa: Based on Wio-SX1262 Wireless Module, supports 862-930MHz
Bluetooth 5.0
GPS
L76K(GPS,BeiDou,GLONASS,QZSS)
OLED Display
Resolution: 128*64 pixels
Active Area(mm): L34.5*W23.0*H1.47
Power
Type-C: 5v---1A
Solar energy interface(2.0mm 2p):5V---1A
Battery interface(1.0mm 2p JST): 3.7v---1A
Certification
FCC, CE, RoHS,EUDOC,TELEC,UKDOC
Hardware Overview
Application
Certification
HSCODE8526919090
USHSCODE8517620090
UPC
EUHSCODE8517180000
COOCHINA
Wio Tracker L1 Board with 1.3 inch OLED Display, 3D-Printed Enclosure and battery
x1
LoRa Antenna
x1
* Regional Availability
This product is not available for sale, shipment, or resale in Mainland China due to regional restrictions.
SKU 100030144
Wio Tracker L1 Pro is a MeshCore-based device featuring low power consumption, a built-in rechargeable battery, and a durable enclosure. Designed for field use, it is ready to use out of the box with no assembly required.  Wio Tracker L1 Pro for MeshCore comes with pre-flashed MeshCore Bluetooth Companion firmware.
USD$44.00
$47.90
Save $3.90(8%)
You may also add
