seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      XY-Plotter Robot Kit v2.0 (With electronic)
      SKU 114990137
      $299.99
      DISCONTINUED
      Stronger structure, super easy stepper motor driver and laser-head compatible -- Makeblock XY-Plotter 2.0 is a fully updated version of XY-plotter. With the Processing and GRemote, the XY-Plotter 2.0 is a drawing robot basically, you can draw amazing pictures with Gcode.
      Since we reinforce the structure, the XY-plotter 2.0 is stronger enough to be converted into MiniCNC, 3D printer, driller, laser cutting machine, etc. And the movement of the terminal is stable and precise since the improved dual-way transmission mechanism.
      We replaced the stepper motor driver to A4988, whose operation is much easier than Me 2H Microstep Driver V1.0.
      FEATURES
      • Stronger aluminum extrusion parts than XY-Plotter 1.0 , anodizing surface
      • Dual-way transmission mechanism
      • Improved pen rising mechanism
      • Super easy-use stepper motor driver, A4988
      • Updated control panel -- Me Baseboard
      • Easy-Controlled by Processing and GRemote
      SPECIFICATION
      • Frame: Anodized aluminum
      • Physical Dimensions(L×W×H): 620mm × 620mm×140mm
      • Working area (X×Y): 310mm×390mm
      • XY Accuracy: 0.1mm
      • Max Engrave Speed: 50mm/s
      • Power: 100-240 V~50/60Hz AC/DC Power adapter, 12V/2.0A
      • Software: GRemote
      • Supports file type: *.CNC(G-code)
      • Connections: USB
      • Electronics: Makeblock Me_baseboard
      Note: The power supply in this kit is USA plug AC to DC wall power supply. You can buy other Power plugs in our website.
      DOWNLOAD
      • Please visit the link to download the software and assembly instruction.
      • https://github.com/Makeblock-official/XY-Plotter-2.0
      • Instruction:http://learn.makeblock.cc/xy2/
      PART LIST
      1 x Beam 0824-16
      10 x Shaft Collar 4mm
      1 x 6P6C RJ25 cable-35cm
      4 x Beam 0824-48
      1 x Flexible coupling 4x4mm
      2 x 6P6C RJ25 cable-50cm
      1 x Beam 0824-80
      4 x Linear Motion Shaft D8X496mm
      1 x Wall Adapter Power Supply - 12VDC
      4 x Beam 0824-96
      6 x Linear Motion Slide Unit 8mm
      1 x USB A-Male to B-Male Cable
      2 x Beam 0824-112
      10 x Flange Bearing 4x8x3mm
      1 x Base Bracket
      2 x Beam 0824-496
      1 x HEX Screwdriver 2.5mm
      4 x  Me Micro Switch B
      1 x Beam 0808-80
      1 x Cross Screwdriver 3mm
      1 x 9g  micro servo bracket
      2 x Beam2424-504
      2 x HEX Allen Key 1.5mm
      1 x Linear Motion Shaft D4x512mm
      2 x Bracket 3x3
      1 x Wrench 7mm
      1 x Linear Motion Shaft D4x80mm
      5 x Plate 3x6
      50 x Nut M4
      3 x Nut M2
      5 x Bracket U1
      10 x Countersunk Screw M3x8
      3 x Cross recessed pan head screw M2x10
      3 x  Belt Connector
      26 x Headless Set Screw M3x5
      30 x Socket Cap Screw M4x14
      2 x 42BYG Stepper Motor Bracket
      16 x Plastic Rivet R4060
      28 x Socket Cap Screw M4x16
      1 x K-Power 9g Micro Servo
      6 x Plastic Rivet R4100
      12 x Socket Cap Screw M4x22
      20 x Plastic Ring 4x7x2mm
      18 x Socket Cap Screw M4x30
      6 x Timing Pulley18T
      1 x Me-Baseboard
      36 x Socket Cap Screw M4x8
      3 x Open-end Timing Belt (1.3m)
      2 x Me Stepper motordriver V1.0
      6 x Cuttable Linkage 3
      2 x D Shaft 4x56mm
      3 x RJ25 Adapter
      30 x Nylon cable ties 2*100
      1 x Threaded Shaft 4x39mm
      2 x 6P6C RJ25 cable-20cm
      5 x Rubber band
      Technical Details
      WeightG.W 4384g
      BatteryExclude
      Reviews
      Questions and Answers
      SUBMIT
        View History
        SKU 114990137
        $299.99
        DISCONTINUED
        $299.99/1pcs+
        $269.99/10pcs+
        $254.99/20pcs+
        $239.99/50pcs+
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
