the AI Hardware Partner
Toggle Nav
Loading...
Xadow - UV Sensor
Xadow UV Sensor is suitable for measuring the UV radiation in sunlight
$7.90
Out of stock
Xadow UV Sensor is suitable for measuring the UV radiation in sunlight. It can detect the UV wavelength of 290 ~ 400 nm. The UV Sensor is outputting digital voltage value corresponding to UV light intensity. With the diagram of output voltage and UV, we can easy to know the current UV index. The Xadow UV Sensor can be powered by 3.3V. And it is compatible with Xadow system.
Xadow is a though small but perfectly formed Arduino(TM) compatible board series containing several modules. It's a kit extremely suitable for space-sensitive projects such as wearable devices & arts designs, which have higher request on size, weight and flexible cascade connection.
You can find more modules here.
Note: This module is not compatible with any other Xadow version 2 or RePhone modules.
DOCUMENTS
Dimensions 0mm x0mm x0mm
Weight G.W 10.5g
Battery Exclude
Documentations
