Ratcheting Crimper Pliers
Do you want to make a Grove connector or female jumper wire? This crimper pliers will be your good helper to meet you need
$16.90
In stock
  • 10+: $16.06
Do you want to make a Grove connector or female jumper wire? This crimper pliers will be your good helper to meet you need. Ratcheting design, get it work with less strength.
  • Capacity : 0.08 - 0.5mm²
  • Length: 19cm
Dimensions 245mm x100mm x20mm
Weight G.W 380g
Battery Exclude
Ratcheting Crimper Pliers 1
ECCN ERA99
HSCODE 8203200000
UPC 841454113935
Product Faqs
Sort by
