LinkIt 7697
Rating:
91% of 100
Lightweight IoT application Cortex-M4 with FPU@192Mhz,Linkit 7697 vs ESP32 Wi-Fi 802.11 b/g/n (2.4G) Support BLE Pin-out for GPIO, I2C, SPI, SPIS, UART, PWM Open software development environment FreeRTOS 352KB RAM and 4MB Flash.
$14.90
In stock
  • 10+: $14.30
  • 20+: $13.90
  • More
  • 50+: $13.35
  • Less
LinkIt 7697 is a co-design product by Seeed Studio and MediaTek. As the latest member of the LinkIt family, it uses the MediaTek MT7697 SoC and aims at providing lightweight IoT solution. It may reminds you of LinkIt Smart 7688/Duo, another development board which released in 2015. Both of them are born for IoT however they are quite different.
The chipset of LinkIt 7697 is MT7697, a highly integrated single chip which features an application processor, a low power 1x1 11n single-band Wi-Fi subsystem, a Bluetooth subsystem, and a Power Management Unit. The application processor subsystem contains ARM Cortex-M4F MCU. It also includes many peripherals, including UART, I2C, SPI, I2S, PWM, IrDA, and auxiliary ADC.
For programming, you can program the board with the native LinkIt SDK using GCC, IAR embedded workbench, or KEIL uVision. In order to make it easier to use, LinkIt 7697 also provides a porting layer to the popular Arduino IDE - so that you can use your existing Arduino sketches and peripheral driver libraries.
If comparing with Arduino UNO, you will find that the LinkIt 7697 is more powerful as it can run more complicated and store larger program, IoT application friendly and cost effective, you can even plug it into a breadboard directly and start your IoT project right away.
  • Lightweight IoT application
  • Cortex-M4 with FPU@192Mhz
  • Wi-Fi 802.11 b/g/n (2.4G)
  • Support BLE
  • Pin-out for GPIO, UART, I2C, SPI, PWM, EINT, ADC, IrDA, I2S
  • Open software development environment FreeRTOS, Arduino, BlocklyDuino
  • 352KB RAM and 4MB Flash.
  • CE, FCC, NCC certified
Hardware Overview
Product Name
LinkIt 7697
Module
wrtnode7 (wrtnode.com)
Chipset
MT7697
Cortex-M4 with FPU @ 192Mhz
RAM
352 KB
Flash
4 MB
Wi-Fi
802.11 b/g/n (2.4G)
Bluetooth
4.2 LE
Dimension
48x26 mm
Operating Voltage
3v3
Input Voltage
5v (microUSB)
USB2UART
CP2102N
Peripheral Interfaces
GPIO x18
UART x2
I2C x1
SPI x1
PWM x18
EINT x4
ADC x4 (0~2.5V)
IrDA x1
I2S x1
Debug Interfaces
SWD x1
Pinout
Get Started
Documents
Dimensions 0mm x0mm x0mm
Weight G.W 9.5g
Battery Exclude
LinkIt 7697 1
ECCN 5A002.a.1
HSCODE 8473309000
USHSCODE 8517620010
UPC 841454119395
FCC 1
CE 1
ROHS 1
Product Faqs
Sort by
