Loading...
MiniDSO DS213 Nano 4 Channel 100MSa/s
MiniDSO DS213 Nano 4 Channel 100MSa/s is based on the DS213, which is a 5-track 4-wire universal electronic engineering task digital storage oscilloscope based on the ARM Cortex M3 core.
$179.00
In stock
Tip
You can also check our blog Introduction to the Oscilloscope – What is an Oscilloscope and How to use it? to learn more about different oscilloscopes
The DS213 is a 5-track 4-wire universal electronic engineering task digital storage oscilloscope based on the ARM Cortex M3 core. Using the FPGA's external ADC's management control and data cache mode of operation, it provides four application partitions for loading and upgrading up to four different application firmware. With a built-in 8MB USB stick, users can store waveforms and upgrade the system firmware.
  • High sampling rate of 100MSa/s
  • Waveform storage and playback
  • Build-in 8MB USB.
  • 5-track-4-channel
  • Color display
  • SainSmart DSO213 Oscilloscope
  • X10 Probe Analyzer ×1
  • X1 Probe Analyzer ×1
  • Instructions x1
  • Hex Key ×1
Dimensions
Sample photo
ParameterValue
Max. sampling rate 100M Sa/s
Analog channel signal bandwidth 15M
Analog channel standard input impedance 1MΩ
Analog channel input coupling AC/DC
Analog channel maximum input voltage ±40V (×1 Probe)
±400V  (×10 Probe)
Horizontal scan time base range 100nS/Div-1S/Div(1-2-5 Step)
Analog channel input sensitivity range 10mV/Div-10V/Div(1-2-5 Step)
Digital channel standard input impedance 100KΩ
Digital channel maximum input voltage 5V
Trigger type Edge trigger, Pulse width trigger
Trigger mode Auto,Normal,Single,Slow
Measurement signal Signal frequency, period, duty cycle, positive pulse width,
negative pulse width, voltage peak-to-peak value,
effective value, average value,
maximum value, minimum value
Signal source 0Hz ~ 8MHz square wave, 10Hz ~ 20KHz
sine wave / triangle wave / sawtooth wave
Battery Built-in 1000mAh lithium battery,
charging with Micro USB port
Dispaly Color TFT LCD display (resolution 240×400)
Storage Built-in U disk storage capacity of 8MB, can
store waveform data and waveform images
HSCODE 9030201000
USHSCODE 90302010
