8mm RGB Led lamp common Cathode (10 PCs)
This 8mm RGB LED (Red Green Blue) with four pins
$5.90
In stock
  • 10+: $5.31
  • 20+: $5.02
  • More
  • 50+: $4.72
  • Less
This 8mm RGB LED (Red Green Blue) with four pins. Triple output one for each color with a common cathode.
This LED can be used for three status indicators or pulse width modulates all three and gets mixed colors!
Please note that this is a pack included 10 units 8mm RGB LEDs.
Features:
  • Common cathode
  • RGB, not only single color.
Specifications:
  • Size:8mm
  • Emitted Color : Red / Green / Blue
  • Lens Color : Water Clear
Documents:
  • You can get the 8mm RGB Led lamp common anode datasheet, they are very similar.
Dimensions 65mm x55mm x8.8mm
Weight G.W 10g
Battery Exclude
8mm RGB Led lamp common Cathode (10 PCs) 1
HSCODE 8541401000
USHSCODE 8541401000
UPC 841454112440
ROHS 1
Product Faqs
Sort by
