the AI Hardware Partner
Toggle Nav
Loading...
WS2812B LED Breakout Board
Integrating control circuit and RGB chip Built-in signal reshaping circuit Built-in electric rest circuit and power lost reset circuit 256 brightness and 16777216 color display
$1.45
Out of stock
  • 10+: $1.31
  • 20+: $1.23
WS2812 is an intelligent control LED light source that the control circuit and RGB chip are integrated in a package of 5050 components. It includes intelligent digital port data latch and signal reshaping amplification drive circuit. Also include a precision internal oscillator and a 12V voltage programmable constant current control part, effectively ensuring the pixel point light color height consistent.
LED with low driving voltage, environmental protection and energy saving, high brightness, scattering angle is large, good consistency, low power, long life and other advantages. The control chip integrated in LED above becoming more simple circuit, small volume, and convenient installation.
This is a breakout board of WS2812B. If you want a 6 pins WS2812 RGB LED, look at here.
  • Integrating control circuit and RGB chip
  • Built-in signal reshaping circuit
  • Built-in electric rest circuit and power lost reset circuit
  • 256 brightness and 16777216 color display
  • Cascading port transmission signal
  • Breakout board
  • Power Supply Voltage: +3.5~+5.3V
  • Input Voltage: -0.5~VDD+0.5V
  • Red Vf: 1.8~2.2V
  • Green Vf: 3.0~3.2V
  • Blue Vf: 3.2~3.4V
  • Red Wavelength: 620~630 nm
  • Green Wavelength: 515~530 nm
  • Blue Wavelength: 465~475 nm
  • Red luminous intensity(20mA): 550~700 mcd
  • Green luminous intensity(20mA): 1100~1400mcd
  • Blue luminous intensity(20mA): 200~400 mcd
WS2812 Datasheet
Dimensions 60mm x60mm x2.8mm
Weight G.W 1g
Battery Exclude
HSCODE 8538900000
ROHS 1
