Loading...
Mini vibration motor SMD
Rating:
100% of 100
This mini vibration motor worked at 3V can be used for multipurposes
$1.20
In stock
  • 10+: $1.08
  • 20+: $1.02
This mini vibration motor worked at 1.3VDC can be used for multipurposes.
Note:Not suitable for precision instruments.
Specification:
Operating condition
Item
Condition remark
2-1
Rated voltage
1.3VDC
2-2
Operating voltage
0.9~1.6VDC
2-3
Rated load
Vibraton weight
As soecufued in outline drawing
2-4
Rated speed
9000±1500rpm
2-5
Rotation
CW(clockwize)
2-6
Motor Position
All position
2-7
Operating environment
-20¬60°C
10¬90%Rh
2-8
Storage environment
-40~80°C
5~95%Eh
No condensation of moisture
Measuremen codition
Item
Condition remark
3-1
Temperature
20±2°C
3-2
Humidity
65±5%RH
3-3
Motor position
Moror shaft horizontal
Lock the motor in a test fixture
All date are based on the measurement under the temperature of 20°C and humidity65%andRH.hower.the langes of temperature5¬35°C and humiddity45¬85%RH  are to be applicable as long as long as no problems.
Dimension:
Dimensions 60mm x50mm x6mm
Weight G.W 2.5g
Battery Exclude
mini vibration motor 1
HSCODE 8501109990
USHSCODE 85011020
UPC 841454115953
Documentations
Learn
  1. Rating
    100%
    By
1 Item
Show per page
