Particle Power Shield with Headers
- 10+: $22.00
The Power Shield is the best way to—you guessed it—provide power to your mobile Particle projects. Based around the MCP73871 battery management controller, this shield allows you to simultaneously power a Photon and charge a connected Li-Ion or Li-Po battery. You'll also be able to monitor battery levels using the Photon itself, which makes the Power Shield the best way to untether your wireless project.
Besides the on-board USB port, you can also use an external DC power supply or solar-cell to charge the battery.
This shield ships with a 3.7V, 400mAh Li-Po battery and headers.
Designed for use with the Photon, backwards compatible with the Core.
Specifications
Operating voltage: USB or External DC of 7 to 20V
Current consumption: 500mA max (USB) & 1.2A max (other DC sources)
Dimensions: 1" x 1.84"
Documents
Please check the datasheet here.
Dimensions | 0mm x0mm x0mm |
Weight | G.W 81g |
HSCODE | 8538900000 |
USHSCODE | 8471490000 |
UPC | 841454119913 |
EUHSCODE | 8543709099 |
COO | CHINA |
RoHS | 1 |
from order viewWork well with my Photon.
