the AI Hardware Partner
Toggle Nav
Loading...
Helical gear set (for 90 degrees transmission)
This helical gear can be used for 90 degrees of transmission
$4.50
Out of stock
This helical gear can be used for 90 degrees of transmission. it has good wear-resistance,low niose,transmission smooth and steady.
Feature:
  • good wear-resistance
  • low niose
  • transmission smooth and steady.
  • Material:Cu+engineering plastics
Specification:
  • Gear A: tooth number(Z):15, Outer diameter:18.6mm, Thickness:6mm, Inner diameter:6mm
  • Gear A: tooth number(Z):10, Outer diameter:12.8mm, Thickness:6mm, Inner diameter:4mm
Dimensions 0mm x0mm x0mm
Weight G.W 9g
Battery Exclude
HSCODE 8483409000
