Skeleton Box 10x10
When you build a Demo, do you want to select a suitable shell for improving whole felling?
Skeleton Box 3
Skeleton Box 3.0 is the newest version, protection circuit device. There are serveral hool sites in Acrylic floor in order to ensure you can install a variety of circuit boards. When you need to lead wire from side to out, you can open expand hole sites in the acrylic panel.Skeleton Box 3.0 includes three modules: big, middle,small.You can choose modules according to individual requirement. More user experience waits for your participation.
Item
Length | Width | Height | Unit |
Skeleton Box 10x7 | 106 | 67 | 36 | mm |
Skeleton Box 10x10 | 106 | 106 | 36 | mm |
Skeleton Box 17x10 | 177 | 106 | 36 | mm |
Dimensions | 160mm x130mm x28mm |
Weight | G.W 139g |
Skeleton Box 10x10 | 1 |
HSCODE | 9023009000 |
UPC | 841454103028 |
COO | CHINA |
RoHS | 1 |
Nice little box I like these boxes and actually put them side way (i.e. the 10x10 facing front) so that I can plan LED display there. One this I like to change is the PCB actually has the LED through power pins (with resistors), which is limiting. If they are connected to signal, then I don't have to hack it (connect to GPIO so I can turn on/off the light). Grove connectors are nice but the one on ether reverse side are pretty much useless. I think some changes will make this product better.
Show
per page
