Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Price Increase Announcement
Date: February 28, 2026
Due to surging demand for modules and SSDs, prices for reComputer and reServer Jetson devices will increase by approximately $50 to $400 in the coming weeks. Please confirm your requirements and place your orders promptly to secure your stock.
  • Robust Hardware Design: A compact, high-performance edge AI computer compatible with NVIDIA Jetson Orin Nano/NX modules in Super/MAXN mode, providing up to 157 TOPS of AI performance.
  • Multiple Interfaces for robotics: Including dual RJ45, M.2 slots for 5G/Wi-Fi/BT modules, 6x USB 3.2, 2x CAN, GMSL2(additional purchase), I2C, and UART, functioning as a powerful robotic brain.
  • Software Setup: Supported JetPack 6.2 and Linux BSP for seamless deployment.
  • Application and Benefit: Ideal for rapid development of autonomous robots, accelerating time-to-market with ready-to-use interfaces and optimized AI frameworks.
  • Wide Operating Range: Operates reliably across a temperature range of -20°C to 60°C at 25W mode and -20°C to 55°C at 40W mode.
Note: To use carrier board in super mode, users would need to design thier own heat dissipation solutions (Thermal Design Guide Provided in Documents section).
Jetson Modules Performance with Super Mode
    • Enhanced power management
    • Improved higher frame rate processing
    • Reduced inference time
Carrier Board
Supported Jetson Module
Jetson Orin Nano/Orin NX
Supported Module Power
7W | 10W | 15W | 20W | 25W | 40W
Storage
1x M.2 KEY M PCIe
Networking
M.2 KEY E
1x M.2 Key E for WiFi/Bluetooth module
M.2 KEY B
1x M.2 Key B for 5G module
Ethernet
2x RJ45 Gigabit Ethernet
I/O
USB
6x USB 3.2 Type-A (5Gbps);
1x USB 3.0 Type-C (Host/DP 1.4)
1x USB 2.0 Type-C (Device Mode/Debug);
Camera
1x 4 in 1 GMSL2(mini fakra)(optional board)
CAN
2x CAN0(XT30(2+2))
3x CAN1(4-Pin GH-1.25 Header)
Display
1x DP1.4(Type C Host)
UART
1 x UART 4-Pin GH-1.25 Header
I2C
2x I2C 4-Pin GH-1.25 Header
Fan
1x 4-Pin Fan Connector (5V PWM)
1x 4-Pin Fan Connector (12V PWM)
Extension Port
1x Camera Expansion Header(for GMSL2 board)
RTC
1x RTC 2-pin
1x RTC Socket
LED
3x LED(PWR, ACT and User LED)
Pinhole Button
1x PWR
1x RESET
DIP Switch
1x REC
Antenna Hole
5x Antenna Hole
Power
19-54V XT30(2+2) (XT30 to 5525 DC Jack Cable included)
Jetpack Version
Supported Jetpack 6.2
Mechanical
Dimensions (W x D x H)
115mm x 115mm x 38mm
Weight
200g
Installation
Desk, Wall-mounting
Operating Temperature
-20℃~60℃(25W Mode)
-20℃~55℃(MAXN Mode)
(with reComputer Robotics heat sink with fan)
Warranty
2 Years
Certification
RoHS, REACH, CE, FCC, UKCA, KC
Robotics Carrier
A608
Voltage
19-54V
9-20V
USB
6x USB 3.0/3.2 Type-A
4x USB 3.2 Type-A
CAN
2x CAN
1x CAN
GMSL
GMSL Extension available
4-lane CSI
N/A
Pricing
$189
$259
Hardware Overview
Application
The NVIDIA AI software stack is designed for accelerate AI application and deployment:
Designed for Edge AI Computer Vision Applications:
Jetson Platform Services provide a platform to simplify development, deployment and management of Edge AI applications on NVIDIA Jetson like BEV sensing demo with 4 USB cameras.
Designed for demanding AI applications:
Such as AMR, smart retail, industrial automation, and video surveillance, smart video analysis scenario
We have Jetson-example prepared for you! It offers one-line deploy projects edge AI applications of generative AI including Ollama, Llama3; computer vision including YOLOv8, and others. We have configured all environment for you to provides single command deployment of projects.
Certification
HSCODE8543909000
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
reComputer Robotics J401 Carrier Board x 1
x1
Power Supply and JST expansion board x 1
x1
XT30 to DC cable x 1
x1
USB Cable, Type A to Type C x 1
x1
Heat Sink for expansion board
x 1
Stud(M3*30)
x 5
M3 Hexagon nut
x 5
Screw(CM2.5*L.4) for Jetson Module and M.2 Key M
x 3
Screw(CM2*3.0) for M.2 Key E
x 1
Stud(M2*2.0) for M.2 Key B
x 1
Screw(CM3*4.0) for M.2 Key B
x 1
User Manual
x 1
reComputer Robotics J401 Carrier Board for Jetson Orin Nano/Orin NX
SKU 114110327
The reComputer Robotics J401 is a compact, high-performance edge AI carrier board designed for advanced robotics. Compatible with NVIDIA Jetson Orin Nano/Orin NX modules in Super/MAXN mode, it delivers up to 157 TOPS of AI performance. Supported  JetPack 6.2 and Linux BSP, it ensures seamless deployment, serving as a powerful robotic brain capable of processing complex data from various sensors.
[10% Off Discount on First Unit Only] From the 2nd unit onward, the original price will apply.
Series
Power Adapter
Supported Processor
USD$189.00
You may also add
