Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Fast boot times and smooth overall experience: Powered by Raspberry Pi Compute Module 4 and 8GB RAM/64GB eMMC
  • Compact and highly integrated: 75x64x21mm in size, with dual Gigabit Ethernet ports and dual USB3.0 ports
  • Highly scalable with rich IO peripherals: dual Gigabit Ethernet connectors, Micro-SD card slot, micro-HDMI interface, USB 3.0, MIPI CSI, MIPI DSI, etc.
  • Easy to deploy with stability: DIN rail mount and keyhole slot allow you to hang it anywhere
  • Pre-installed OpenWRT firmware: Out of the box, can easily implement software router applications
  • Customization Supported: Contact *[email protected]* for your customization needs
Carrier Board
NetworkingDual Gigabit Ethernet Connectors
USB 3.0 to GbE(Gigabit Ethernet Bridge)Microchip's LAN7800
USB2 x USB 3.0 Ports1 x USB 3.0 9-Pin Header
StorageMicro-SD Card Slot (load system Image for non-eMMC CM4 version)
Camera1 x MIPI CSI Connector
Display1 x MIPI DSI Connector1 x Micro HDMI Connector
FPCInterface for I2C and SPI
External FanPower connector for fan
Power5V/3A using USB Type-C Port
LAN7800 IndustrialTemperature Range-40°C to +85°C
Dimensions75x64x21mm
Weight43g
Compute Module 4
ProcessorBroadcom BCM2711 quad-core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz
Memory8GB LPDDR4
Storage64GB eMMC
Connectivity2.4GHz and 5.0GHz IEEE 802.11b/g/n/ac Wi-Fi, Bluetooth 5.0, BLE with onboard and external antenna options
Onboard Gigabit Ethernet PHY supporting IEEE1588
1 × USB 2.0 interface
PCIe Gen 2 x1 interface
28 GPIO signals
SD card interface for SD card or external eMMC
VideoDual HDMI interface (up to 4Kp60 supported)
2-lane MIPI DSI display interface
2-lane MIPI CSI camera interface
4-lane MIPI DSI display interface
4-lane MIPI CSI camera interface
MultimediaH.265 (4Kp60 decode); H.264 (1080p60 decode, 1080p30 encode); OpenGL ES 3.0 graphics
Input power5V DC
Operating temperature0 to +80°C
Dimensions55 mm × 40 mm
Production lifetimeat least January 2034
ComplianceDocuments - Product Information Portal - Raspberry Pi
Hardware Overview
Application
  • Software Router
  • IoT applications
  • Smart Home
  • Camera / Video-related Projects
Certification
HSCODE8471419000
USHSCODE8517180050
UPC
EUHSCODE8471707000
COO
Dual Gigabit Ethernet Carrier Board for Raspberry Pi CM4 with 8GB RAM, 64GB eMMCx1
Aluminum Casex1
International Wall Adapter Power Supply 5VDC 4A – Type-C (with US/AU/UK/EU plugs)x1
reRouter CM4 108064 - Raspberry Pi Based Mini Router, Travel Router, Dual Gigabit Ethernet, OpenWRT OS
SKU 100040019
The Mini Router is pre-installed with a custom OpenWRT system and equipped with dual Gigabit Ethernet ports, dual USB 3.0 ports, and a Raspberry Pi Compute Module 4 with 8GB RAM and 64GB eMMC. The full system makes it suitable for soft router applications while keeping the hardware to a minimum. Discover More Raspberry Pi Powered Edge HMI, Controller, and Edge IoT Devices.
USD$294.00
