Flow switch--MR-W1-P
This sensor works as a switch, conducts while flow pass though
$12.99
Out of stock
  • 10+: $11.69
  • 20+: $11.04
This sensor works as a switch, conducts while flow pass though.
Specifications
  • Max switch current: 0.5 A
  • Max load current : 1.0 A
  • Max resistance: 100 ohm
  • Max load power: 10 w
  • Max switch voltage: 100 vdc
  • Min damage voltage: 220 vdc
  • Min sensible flow: ≥0.1L/MIN
  • Working flow range: 1-30L/MIN
  • Min sensible pressure: ≥0.1 mpa
  • Min water pressure: 0. 1 mpa
  • Max water pressure: 1.2 mpa
  • Working temperature: 1-80°C
  • Storage temperature: -20-10°C
  • Life: >108 times
  • Response time : 0.2 sec
  • Release time : 0.2 sec
Documents
Dimensions 100mm x80mm x26.5mm
Weight G.W 27g
Battery Exclude
Product Faqs
Sort by
