Temperature sensor with steel head
Rating:
100% of 100
This Analog Temperature Sensor consists of a metal temperature probe and a 58cm long cable, featuring a wide temperature range in -25°C to 125°C, suitable for immersive temperature detection
$1.50
In stock
  • 10+: $1.35
  • 20+: $1.28
  • More
  • 50+: $1.20
  • Less
This Analog Temperature Sensor consists of a metal temperature probe and a 58cm long cable, featuring a wide temperature range in -25°C to 125°C, suitable for immersive temperature detection. If you want to use it with Arduino, simply connect it as the picture below
Please note that the cable part cannot be put under temperature higher than 105°C.
  • Waterproof
  • Linear resistor
  • Easy to use
Documents
Dimensions 0mm x0mm x0mm
Weight G.W 7g
Battery Exclude
ECCN ERA99
HSCODE 9025900090
UPC 841454116233
ROHS 1
Product Faqs
Sort by
