0.8 Inch 16 Segment LED White - Common Anode
  • 0.8 Inch 16 Segment LED White - Common Anode
SKU 104990130
This is a 16 segment common cathode LED and is white
$1.95
DISCONTINUED
This is a 16 segment common cathode LED and is white. The advantage of 16 segment is that you can not only display 1234567890, but also ABCDEFGHIJKLM.
It is compatible with bread board and can work with Arduino by adding some current limiting resistors. So, it Suitable for people who is newbie of electronic.
Note: It just a segment LED without control chip.
High Light
low current
low-voltage
low energy
Longevity
IC-compatible
0.80 inch
common port: 11
size: 20.0 x 27.7 x 8.5mm
Colors: white
surface colors: Black
Working temperature: -20~60°C
Mechanical Outline:
Unspecified Tolerances is: X±0.2
Absolute Maximum Ratings
Parameter
Symbol
Maximum Rating
Unit
Power Dissipation
Pd
mW
Peak Forward Current
Ifp
150
mA
Continuous Forward Current
Ifm
20
mA
Reverse Voltage
VR
5
V
Operating Temperature Range
           topr
-40 → +85
Storage Temperature Range
Tstg
 -40 → +100
Static Voltage
Var
V
* Lead Sodering Temperature:260℃  for 3 seconds
* For  operation above 25℃,  The Ifm Ifp & Pd must be derated, the Curent derating is –0.36mA/℃ for  DC drive and  -0.86mA/℃ for Pulse drive, the power dissipation is  -0.75mW/℃. The product working current must not more than the 60% of the Ifm or Ifp according to the working temperature.
Optical-Electrical Characteristic
Parameter
Test CONDITING
Symbol
Min
Type
Max
Unit
Luminous Intensity
IF=10mA
Iv
80.5
85.5
89.7
Mcd
Forward Voltage
IF=10mA
VF
3.0
V
REVERSE Current
VR = 5V
IR
80
uA
Peak Wavelength
IF=10mA
λp
461.3
465.2
468.7
nm
Spectral Bandwidth
IF=10mA
△λ
40
nm
View Angle
IF=10mA
2θ1/2
Deg.
Storage & Soldering Condions:
Store with care. Storing the units in bad condition will cause the reflector sheet and decrease it’s adhesive  power. Storage  the  products  under  the condition :temperature ( 25℃ ± 10℃ ) and humidity (65℃ CRH±20℃ CRH) our recommendation.
The Soldering Temperature is 260±5℃ and Soldering Time should be less than 3 sec, and soldering iron power should be less than 30W.
The soldering point should be farther than 1.6mm from boby.
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Questions and Answers
SUBMIT
See More
View History
Recommendations
SUBMIT
Invalid email address.
