Many people like solar energy because it is simple, clean and renewable. Especially when you are building out-door projects, solar energy is one of the best solutions for power supply. Depending on the project you are going to build, there are many different size of solar panel to choose, If you are looking for a portable solar panel, why not look at this small solar panel that we are going to introduce today-----0.5W Solar Panel 55x77.
0.5W Solar Panel 55x77 is monocrystalline silicon solar panel, which is the main trend in the future. Comparing to polycrystalline silicon solar panel and thin-film solar panel, monocrystalline silicon solar panel performs higher conversion rate that up to 17%. The surface is covered by fine resin which makes it water-proof, together with a very sturdy back, it is really suitable for out-door environment.
Depending on light intensity, the typical open circuit voltage is 5V. If you take it to a summer day with bright sunshine and no cloud in the sky, the peal OC voltage can be up to 10V. Because the voltage range is relatively wide, if you are going to use boards that require narrow range of input voltage, such as Lipo Rider, to prevent any damage, please check whether the OC voltage is acceptable for the board before any connection.
To begin with, we recommend you to choose some of the solar panel compatible board produced by Seeed such as Seeeduino microcontroller series, Lipo Rider charging board series and Xbee Carrier WSN products series. Since A 2mm JST connector is attached to the panel, it is perfect to team up with the boards that recommended above.
Despite all the goof features, it is really a very cheap solar panel among solar panel kits. Again, if you are looking for portable solar panels for sale, 0.5W Solar Panel 55x77 is the best choice!
FEATURES
• Dimensions: 70x55x3(±0.2) mm
• Typical voltage: 5.5V
• Typical current: 100mA
• Open-circuit voltage: 8.2 V
• Maximum load voltage: 6.4V
DOCUMENTS
