Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Note:
Some product photos show a '2.4G' marking. The linked datasheet for this SKU specifies 2400–2500 MHz and 5100–5900 MHz. Check the part number against the datasheet when integrating a unit with different markings. Supported operating bands also depend on the connected board.
  • Dual-band antenna, board-specific operation: Covers 2400–2500 MHz and 5100–5900 MHz. XIAO ESP32-C3 uses 2.4 GHz only; XIAO ESP32-C5 supports 2.4 and 5 GHz Wi-Fi. Replacing an antenna does not add frequency bands to a board.
  • Measured RF characteristics: Peak gain of 2.16 dBi at 2450 MHz and 2.80 dBi at 5420 MHz, with 50 Ω nominal impedance. Maximum measured efficiency is 71.49% at 2450 MHz; gain and efficiency vary with frequency and installation.
  • Compact integration: A 40 × 20 × 0.2 mm FPC radiator with an 80 mm, Ø1.13 mm cable and an IPEX1 connector for compact IoT enclosures.
  • Replacement or spare: Use for replacing a damaged antenna, keeping a project spare, or planning an enclosure layout. XIAO ESP32-C3 and XIAO ESP32-C5 already include an external antenna; this accessory is not a required extra purchase.
Installation and Cable Routing
  1. Disconnect power before attaching the antenna. Align the IPEX1 plug directly over the matching board socket, then press gently straight down. Do not force an angled or mismatched connector.
  2. Route the cable with gentle bends and provide slack at the connector. Do not pull on the cable or sharply crease the FPC radiator.
  3. Keep the radiating section away from metal surfaces, batteries, and large ground planes where possible. Check signal strength in the final enclosure before fixing its position.
Recommended Uses
Compact Wi-Fi sensor nodes, smart-home prototypes, enclosure integration, and replacement or spare antennas for supported XIAO projects.
Choose a board: XIAO ESP32-C5 — 2.4/5 GHz Wi-Fi; XIAO ESP32-C3 — 2.4 GHz Wi-Fi. Development boards are sold separately from this antenna.
A-01 Datasheet — dimensions, connector and RF test data · C3 Getting Started · C5 Wi-Fi Guide
Parameter
Frequency Bands
2400MHz~2500MHz
5100MHz~5900MHz
Peak Gain, dBi (Typ)
2.16 dBi at 2450 MHz; 2.80 dBi at 5420 MHz (highest measured value)
VSWR(Max)
3:1
Nominal Impedance
50Ω
Maximum Measured Efficiency
71.49% at 2450 MHz (peak; not constant across bands)
Operational Temperature Range
-40℃ to +85℃
Storage Temperature Range
-40℃ to +85℃
Polarization
Linear
Material Substance Compliance
REACH/RoHS Compliance
FPC Radiator Dimensions (L × W × T)40 × 20 × 0.2 mm
Cable Length / Diameter80 mm / Ø1.13 mm
ConnectorIPEX1
Board Band CompatibilityXIAO ESP32-C3: 2.4 GHz only; XIAO ESP32-C5: 2.4/5 GHz
Antenna Selection Guide
Match the operating band and connector first, then check radiator size and cable length for your enclosure. Peak gain values are not constant across the operating band.
ParameterFPC Antenna A-02FPC Antenna A-012.4 GHz Rod Antenna
Operating Bands2.4 GHz2400–2500 MHz; 5100–5900 MHz2.4 GHz only; not for 5 GHz Wi-Fi
ConnectorCheck the linked product datasheetIPEX1Check the linked product datasheet
Radiator DimensionsCheck the linked product drawing40 × 20 × 0.2 mmCheck the linked product drawing
Cable LengthCheck the linked product drawing80 mmCheck the linked product drawing
Listed XIAO CompatibilityXIAO ESP32-S3 / S3 Sense: 2.4 GHzXIAO ESP32-C3: 2.4 GHz; XIAO ESP32-C5: 2.4/5 GHz; XIAO ESP32-S3 Plus: 2.4 GHzXIAO ESP32-C3, C6 and ESP32-S3 Plus: 2.4 GHz; XIAO ESP32-C5: 2.4 GHz only with this rod antenna
Peak Gain1.16 dBi2.16 dBi at 2450 MHz; 2.80 dBi at 5420 MHz2.81 dBi
VSWR (Max)4.5:13:13.0:1
PolarizationLinearLinearLinear; omnidirectional pattern
Hardware Overview
Application
  • Industrial Sensor Networks
  • Agricultural Telemetry Systems
  • Drone Swarm Relays
  • Embedded IoT Gateways
Documents
Certification
HSCODE8517710000
USHSCODE8517710000
UPC
EUHSCODE8471707000
COOCHINA
FPC Antenna A-01 (2.4/5 GHz, IPEX1, 80 mm cable) for XIAO ESP32-C3/C5
×1
FPC Antenna A-01 for Seeed Studio XIAO ESP32-C3/C5
SKU 318020748
A compact 2.4/5 GHz FPC antenna with an IPEX1 connector and 80 mm cable for XIAO ESP32-C3/C5 projects. Use it as a replacement, spare, or for enclosure integration. XIAO ESP32-C3 operates at 2.4 GHz; XIAO ESP32-C5 supports 2.4 and 5 GHz. Antenna dimensions: 40 × 20 × 0.2 mm.
USD$0.50
You may also add
