Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Note:This FPC antenna is equipped with an I-PEX MHF4 series connector. During installation, do not apply excessive force to avoid damaging the antenna connector. After installation, avoid frequent plugging and unplugging to prolong the antenna’s service life.
  • Mini Antenna for Tiny Seeed Studio XIAO nRF54L15:Attach everything you need to enhance the tiny MCU board’s 2.4 GHz wireless capability. In real-world testing, XIAO nRF54L15 with this external antenna achieved communication distances up to 180 meters in open outdoor environments.
  • Suitable for Bluetooth LE 6.0 Channel Sounding:The external FPC antenna improves link budget and radiation quality on XIAO nRF54L15, enhancing stability and precision for distance/ranging.
  • Boosted Bluetooth stability:Matched to 50 Ω with VSWR ≤ 2.0 across 2400–2500 MHz, ensuring stable, low-loss BLE connectivity with XIAO nRF54L15.
  • High efficiency & reliable range:Delivers up to 1.86 dBi peak gain (at 2430 MHz) and 67.6% max efficiency (at 2450 MHz) for stronger 2.4 GHz coverage and extended range.
  • Slim, flexible integration:Flexible FPC antenna with Ø0.81 × 50 mm coax (IPEX 4), plus 3M adhesive for quick mounting on non-conductive surfaces—ideal for tight spaces.
Parameter
Frequency Range
2400–2500 MHz
Impedance
50 Ω
Max Efficiency
67.6% @ 2450 MHz
VSWR
≤ 2.0
Polarization
Linear
Dimensions
35.2 × 8.5 mm
Cable
RG0.81 mm, 50 mm length
Connector
IPEX 4
Operating Temp
-40 °C ~ +85 °C
Material Substance Compliance
REACH/RoHS Compliance
Antenna Selection Guide
Hardware Overview
Application
  • Industrial Sensor Networks
  • Agricultural Telemetry Systems
  • Drone Swarm Relays
  • Embedded IoT Gateways
Documents
Certification
HSCODE8517710000
USHSCODE8517710000
UPC
EUHSCODE8531202090
COOCHINA
2.4GHz FPC Antenna (1.86dBi) for XIAO nRF54L15
×1
2.4GHz FPC Antenna A-04 for XIAO nRF54L15
SKU 100039813
It’s a 2.4 GHz, 1.86 dBi flexible FPC antenna purpose-built for Seeed Studio XIAO nRF54L15, featuring an IPEX 4 connector. Using this external antenna improves BLE link stability and extends range, in a slim form factor with Ø0.81 × 50 mm coax.
USD$0.90
