Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Note:
Due to product updates, shipments may contain items with either the new or previous silk-screen markings. While the product's performance, quality standards, and functionality remain identical. You may use these products with full confidence.
  • 2.4 GHz replacement or spare: FPC Antenna A-02 for XIAO ESP32-S3 and XIAO ESP32-S3 Sense Wi-Fi/Bluetooth projects. Operating band: 2400–2500 MHz; this is not a 5 GHz antenna.
  • Verified RF performance: Peak gain of 1.16 dBi at 2500 MHz, maximum measured efficiency of 61.84% at 2500 MHz, and 50 Ω nominal impedance. Gain is 0.32 dBi at 2450 MHz; RF performance varies with frequency and enclosure layout.
  • Enclosure integration: A 37.4 × 17.5 mm FPC radiator with a 65 mm, Ø1.13 mm coaxial cable and an I-PEX 1 connector.
Installation and Cable Routing
  1. Disconnect power before attaching the antenna. Align the first-generation I-PEX plug with the matching socket, then press gently straight down. Do not force a mismatched or angled connector.
  2. Route the cable with gentle bends and leave slack at the connector. Do not pull on the cable or sharply crease the FPC.
  3. Keep the radiating section away from metal, batteries, and large ground planes where practical. Check signal strength in the final enclosure before securing the antenna.
Recommended uses: compact Wi-Fi/Bluetooth nodes, enclosure integration, and replacement or spare antennas. No fixed communication distance is guaranteed.
Choose XIAO ESP32-S3 / S3 Sense · Getting Started · A-02 Datasheet and Engineering Drawing. Development boards are sold separately from this antenna.
ParameterDescription
Frequency Bands2400–2500 MHz (2.4 GHz only)
Peak Gain1.16 dBi at 2500 MHz (highest measured); 0.32 dBi at 2450 MHz
VSWR (Max)4.5:1
Nominal Impedance50 Ω
Maximum Measured Efficiency61.84% at 2500 MHz; varies with frequency and installation
FPC Dimensions (L × W)37.4 ± 0.2 × 17.5 ± 0.2 mm
Cable Length / Diameter65 ± 2 mm / Ø1.13 ± 0.1 mm
ConnectorI-PEX 1 (first-generation connector)
Maximum Solder Joint Height≤1.80 mm, including release paper (per engineering drawing)
Temperature Range-40°C to +85°C (per datasheet; storage range is not separately specified)
PolarizationLinear
Material Substance ComplianceRoHS compliant (per linked datasheet)
Listed Board CompatibilityXIAO ESP32-S3 / S3 Sense: 2.4 GHz
Antenna Selection Guide
Match the operating band and connector first, then check radiator size and cable length for your enclosure. Peak gain values are not constant across the operating band.
ParameterFPC Antenna A-02FPC Antenna A-012.4 GHz Rod Antenna
Operating Bands2400–2500 MHz2400–2500 MHz; 5100–5900 MHz2400–2500 MHz only; not for 5 GHz Wi-Fi
ConnectorI-PEX 1 (first-generation connector)IPEX1SMA-Female antenna; included SMA-to-I-PEX adapter to board
Antenna Dimensions37.4 ± 0.2 × 17.5 ± 0.2 mm (FPC outline)40 × 20 × 0.2 mm (FPC radiator)Ø13 ± 0.5 × 134 ± 5 mm (housing)
Cable Length65 ± 2 mm; Ø1.13 ± 0.1 mm coaxial cable80 mmTBD — included SMA-to-I-PEX adapter cable
Listed XIAO CompatibilityXIAO ESP32-S3 / S3 Sense: 2.4 GHzXIAO ESP32-C3: 2.4 GHz; XIAO ESP32-C5: 2.4/5 GHz; XIAO ESP32-S3 Plus: 2.4 GHzXIAO ESP32-C3, C6 and ESP32-S3 Plus: 2.4 GHz; XIAO ESP32-C5: 2.4 GHz only with this rod antenna
Peak Gain1.16 dBi at 2500 MHz (highest measured)2.16 dBi at 2450 MHz; 2.80 dBi at 5420 MHz2.81 dBi
VSWR (Max)4.5:13:13.0:1
PolarizationLinearLinearLinear; omnidirectional pattern
Source documents: A-02 datasheet and drawing; A-01 datasheet and drawing; Rod antenna datasheet and housing drawing. The rod kit includes a SMA-to-I-PEX cable; its length is TBD because it is not specified in the published antenna datasheet.
Hardware Overview
Application
  • Industrial Sensor Networks
  • Agricultural Telemetry Systems
  • Drone Swarm Relays
  • Embedded IoT Gateways
Documents
Certification
HSCODE8517710000
USHSCODE8517710000
UPC
EUHSCODE8531202090
COOCHINA
FPC Antenna A-02 (2.4 GHz, I-PEX 1, 65 mm cable) for XIAO ESP32-S3 / S3 Sense×1
2.4GHz FPC Antenna A-02 for XIAO ESP32-S3
SKU 318020968
A 2.4 GHz FPC antenna for XIAO ESP32-S3 and XIAO ESP32-S3 Sense, with a 37.4 × 17.5 mm radiator, 65 mm cable and first-generation I-PEX connector. Use it as a replacement, spare, or for enclosure integration. Supports 2400–2500 MHz only; not for 5 GHz Wi-Fi.
USD$0.50
