Loading...
3W RGB LED strip common anode 12V
Rating:
100% of 100
‍‍The LED strip uses trinity-SMD LED as lighting source, it shines uniformity with high brightness
$3.50
Out of stock
  • 10+: $3.15
  • 20+: $2.98
  • More
  • 50+: $2.80
  • Less
The LED strip uses trinity-SMD LED as lighting source, it shines uniformity with high brightness. The FPC circuit board made it easily to bend with lowing voltage with resistance and having IC constant current, stable working was ensured. Designed with two solder pan, convenient for connected.
Dimensions 0mm x0mm x0mm
Weight G.W 5g
Battery Exclude
HSCODE 9405409000
Documentations
Learn
  1. Rating
    100%
    By
1 Item
Show per page
