4.3 Inch Raspberry Pi Display Pack
SKU 104110004
139.00
DISCONTINUED
The 4.3” Raspberry Pi Display Module is a Raspberry Pi Display Module Pack, which includes a 4.3" Resistive Touch LCD Display with Resistive Touch, a 4D Pi Adaptor and 5 way interface cable.
The 4.3” Raspberry Pi Display Module customises the uLCD-43PT Display specifically for interfacing with the Raspberry Pi, to provide a quick and easy interface without any wiring hassles.
The Raspberry Pi Display Module Pack enables a Raspberry Pi user to quickly connect the 4D Pi Adaptor Shield to their Raspberry Pi, connect the 5 way cable between the Adaptor and the Display Module, and be connected in seconds to start programming their new 4D Systems Display.
The uLCD-43PT-PI has a comprehensive ViSi-Genie library written to communicate with the Raspberry Pi, allowing the Visi-Genie events to be easily understood by the Raspberry Pi and users code.
Utilises the Raspberry Pi's UART Serial Port.
  • Powerful Graphics
  • Low-Cost Display Solution
  • PICASO Processor
  • Easily Connect to your Raspberry Pi
Software
  • Introducing 4D Systems' All New Workshop4 IDE
  • Supports multiple development environments, to cater for different user requirements and skill level.
  • Workshop4 is a comprehensive software IDE for Microsoft Windows that provides an integrated software development platform for all of the 4D family of processors and modules.
  • The IDE combines the Editor, Compiler, Linker and Downloader to develop complete 4DGL application code. All user application code is developed within the Workshop4 IDE.
  • Workshop4 includes four development environments, for the user to choose based on application requirements or even user skill level.
Liberaries
DEMO
PMMC/FIRMWARE
NOTE
  • This product only support Raspberry Pi, do not support Raspberry 3B or A+ 、 B+.
  • Please note that the 4.3” Raspberry Pi Display Module is not designed to be the primary display for the Raspberry Pi and is programmed using 4D Systems' Workshop 4 IDE
  • For support relating to the Raspberry Pi, please refer to the Raspberry Pi Forum
Technical Details
Dimensions210mm x 105mm x 40mm
WeightG.W 230g
BatteryExclude
4.3"Resistive Touch LCD Display with Resistive Touch1
4D Pi Adaptor1
5 way interface cable1
ECCNNot Available
Certification
RoHSCompliant
Reviews
Questions and Answers
SUBMIT
0
Can you confirm whether this will work on a Raspberry Pi 3, Model B, thanks
on Jan 06,2018
Reply upvote ()
Hi Jorden~ Unfortunately, this one is not compatible with Raspberry Pi 3, Model B. This is the old version for Raspberry Pi only. You can seach this one 3.5 inch SKU 114991415 or 5 inch SKU 104990342 .Both one above can work with Raspberry Pi 3, Model B. Regards
on Jan 08,2018 15:04 PM
Reply upvote ()
The actual interface to the display is TX,RX,5V,GND,Reset and it's only the 5-26-pin adapter that doesn't work with the 40-pin Raspi models. But the data sheet also says that it's not intended as a primary display for the Raspi - it's an intelligent graphics processing engine on its own, with a programming interface designed to send objects to it, rather than the usual dumb display that you send pixels from the processor. (It also has a touchscreen and audio connections, an SD-card reader, and a second serial port so you can drive it from other devices, like PCs or Arduino, If you want to hack, this looks like lots of fun. If you want plug-and-play, you can find easier things, but you could build a cable or use one of the Raspi breadboard adapters and 4 wires.
on Jan 25,2018 02:43 AM
Reply upvote ()
Reply
    View History
    SKU 104110004
    $139.00
    DISCONTINUED
    $139.00/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
