Adjustable DC&DC Power Converter (1.25V - 35V&3A)
- 10+: $3.51
This is a DC/DC step-down voltage regulator that converts input voltage between 3.2V and 40V into a smaller voltage between 1.25V and 35V, capable of driving a 3A load with excellent line and load regulation.
In some projects, you might need different voltages (3-35V) for your devices. Without this kind of DC power source, you’ll find it time-consuming to buy a new one. The delay of project is so annoying. No worries! This module can accelerate prototyping, because you can get the voltage you need (such as 3.3V, 5V and 9V) as easy as blinking eyes.
Note: Input must be >1.5V higher than output.
Wide Output Voltage Range
Ensured 3A Output Load Current
Input Voltage Range Up to 40V
Excellent Line and Load Regulation
Low Power Standby Mode, Typically 80uA
High Efficiency Up to 92%
Precise potentiometer for voltage adjustment
Thermal Shutdown and Current Limit Protection
Specifications
Input Voltage: 3.2V - 40VDC
Output Voltage: 1.25V - 35VDC
Max. Output Current: 3A
Max. Efficiency: 92%
Output Ripple: ≤100mV
Switching Frequency: 65KHz
Operating Temperature: -45℃ to +85℃
Dimensions: 43mm*21mm*14mm(l*w*h)
Dimensions | 0mm x0mm x0mm |
Weight | G.W 12g |
Adjustable DC&DC Power Converter (1.25V - 35V&3A) | 1 |
HSCODE | 8504909090 |
USHSCODE | 8504902000 |
UPC | 841454112310 |
COO | CHINA |
RoHS | 1 |
