seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      AlphaBot2 robot building kit for Raspberry Pi Zero/Zero W (no Pi)
      SKU 110060862
      $85.99
      10 Available
      $85.99/1pcs+
      $81.69/10pcs+
      $77.39/20pcs+
      $73.09/50pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      Note: Raspberry Pi Zero/Zero W is NOT included.
      This AlphaBot2 robot kit is designed to use with Raspberry Pi Zero/Zero W (not included). It features rich common robot functions including line tracking, obstacle avoiding, ultrasonic ranging, Bluetooth/infrared/Wi-Fi remote control (Bluetooth and Wi-Fi are Zero W specific), video monitoring, etc.
      Thanks to the highly integrated modular design, it is fairly easy to assemble by a snap, no soldering, no wiring. After a few minutes spent on hardware assembled, you're almost there, our open source demo codes will ready to help you get started fast.
      AlphaBot2 employs a 2-layer structure to provide excellent stability and compatibility.
      AlphaBot2-Base, the lower base chassis:
      •5-ch infrared sensor, analog output, combined with PID algorithm, stable line tracking
      •Onboard modules like line tracking, obstacle avoiding, needs no messy wiring
      •TB6612FNG dual H-bridge motor driver, compared with L298P, it's more efficient, more compact, and less heating
      •N20 micro gear motor, with metal gears, low noise, high accuracy
      •Onboard RGB LEDs, true color lighting, pretty cool
      AlphaBot2-PiZero, the upper adapter board for controller:
      •LM2596 voltage regulator, provides the Pi with stable 5V power
      •TLC1543 AD acquisition chip, allows the Pi to use analog sensors
      •PCA9685 servo controller, make it more smoothly to rotate the pan head
      •CP2102 UART converter, easy for controlling the Pi via UART
      •USB HUB chip, more USB ports for devices like NIC
      What's on the AlphaBot2-Base
      1.AlphaBot2 control interface: for connecting sorts of controller adapter board
      2.Ultrasonic module interface
      3.Obstacle avoiding indicators
      4.Omni-direction wheel
      5.ST188:reflective infrared photoelectric sensor, for obstacle avoiding
      6.ITR20001/T: reflective infrared photoelectric sensor, for line tracking
      7.Potentiometerfor adjusting obstacle avoiding range
      8.TB6612FNG dual H-bridge motor driver
      9.LM393 voltage comparator
      10.N20 micro gear motor reduction rate 1:30, 6V/600RPM
      11.Rubber wheels diameter 42mm, width 19mm
      12.Power switch
      13.Battery holder: supports 14500 batteries
      14.WS2812B: true color RGB LEDs
      15.Power indicator
      What's on the AlphaBot2-PiZero
      1.AlphaBot2 control interface: for connecting AlphaBot2-Base
      2.LM2596:5V voltage regulator
      3.Raspberry Pi interface: for connecting Raspberry Pi Zero/Zero W
      4.IR receiver
      5.Buzzer
      6.FE1.1S: USB HUB chip
      7.12M crystal
      8. USB TO UART: easy for controlling the Pi via UART
      9.USB HUB interface: extends the USB port of Raspberry Pi Zero/Zero W
      10.CP2102:USB TO UART converter
      11.PCA9685:servo controller, make it more smoothly to rotate the pan head
      12.TLC1543: 10-bit AD acquisition chip, allows the Pi to use analog sensors
      13.Servo interface
      14. USB indicators
      15.USB ports: more USB capability
      Examples
      Note: photos are FOR REFERENCE ONLY, the other boards/modules/accessories are NOT included in the package list.
      Technical Details
      Dimensions220mm x 165mm x 70mm
      WeightG.W 399g
      BatteryExclude
      AlphaBot2-PiZero (adapter board)1
      AlphaBot2-Base (base chassis) 1
      RPi Camera (B) 1
      Ultrasonic sensor 1
      Micro SD Card 16GB 1
      Power adapter US standard 5V/2.5A USB output 1
      SG90 servo 2
      2 DOF pan and tilt kit 1
      IR remote controller 1
      FC-20P cable 8cm 1
      Micro USB connector 1
      RPi Zero V1.3 Camera Cable 30cm1
      USB type A plug to micro B plug cable1
      AlphaBot2-PiZero screws1
      Screwdriver1
      Micro SD Card Reader 1
      Reviews
      Questions and Answers
      SUBMIT
        View History
        SKU 110060862
        $85.99
        10 Available
        Maximum Qty: 5
        $85.99/1pcs+
        $81.69/10pcs+
        $77.39/20pcs+
        $73.09/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • Related
        • View History
        SUBMIT
        Invalid email address.
