Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Note: This is a white-label version with no branding. If you’re looking for the branded SenseCAP version, please check:
  • Seamless indoor and outdoor positioning
T1000 effectively employs BLE and Wi-Fi for pinpoint indoor positioning and utilizes GNSS technologies, including GPS, Beidou, Galileo, and GLONASS for precise outdoor tracking.
  • Months of battery after a single magnetic charge
With magnetic charge design to enhance water resistance. (PS: Battery life depends on upload interval, work mode, etc., please refer to datasheet)
  • Offline data storage up to 1000 records
When temporarily disconnected from the LoRaWAN network, the tracker can store up to 1000 location records locally. All data will be automatically uploaded once the connection is restored.
  • White-label ready for rapid integration
Delivered with a clean, unbranded appearance to support fast OEM deployment—perfect for businesses looking to add their own branding, customize protocols, or scale product lines without starting from scratch.
General Parameters
Backhaul
LoRaWAN® (v1.0.4 Class A)
Bluetooth
Bluetooth v5.1, setting via App
LoRaWAN Channel Plan
IN865/EU868/US915/AU915/AS923/ KR920/RU864
Temperature
Range: -20 to 60℃ ; Accuracy: ± 1℃
Resolution: 0.1℃
Light
0 to 100% (0 is dark, 100% is brightest )
3-Axis Accelerometer
3-Axis Accelerometer to detect movement
LED and Buzzer
1*LED and 1* buzzer to indicate status
Button
1*Button to operate and trigger events(SOS)
Antenna
Internal (GNSS/LoRa/Wi-Fi/BLE)
Communication Distance
2 to 5km (depending on gateway antenna, installation, and environments)
IP Rating
IP65
Dimensions
85 x 55 x 6.5 mm
Device Weight
32g
Operating Temperature
-20℃ to +60℃
Operating Humidity
5% - 95% (No condensation)
Certification
CE /FCC /TELEC /RoHS /REACH
Location
GNSS Constellation
GPS/GLONASS/Galileo/ BeiDou/QZSS
GNSS Sensitivity
-145dBm cold start / -160 dBm Tracking
GNSS Location Accuracy
~1m CEP, GPS, -130dBm
Wi-Fi Positioning
Passive scanning, uploads the scanned 4 MAC addresses
Bluetooth Positioning
uploads the scanned 3 best signal MAC addresses of Beacon
Data Cache
Cache 1000 data when there is no LoRaWAN network
Battery
Battey Capacity
Rechargeable lithium battery, 700mAh
*Battery Life Estimates
4 months on a single charge(uplink every 1 hour, only GNSS data)
Battery Life Monitoring
Periodic uplink battery level
Charge Cable (Adapter not included)
USB magnetic charging cable, 1 meter
Power Input Voltage
4.7 to 5.5V DC
Charging Temperature
0 to +45℃ (Beyond the temperature range, the charge will be limited, and the LED will blink quickly)
Software
Work Mode
Standby: only heartbeat uplink; Periodic: upload location in intervals; Event: modify the interval by temperature, light and motion(start, end, shock, motionless timeout);
Data Storage
Over 1000 location data records store on the device when there is no LoRaWAN® coverage
App
Configuration via Bluetooth App
Hardware Overview
Certification
HSCODE9031809090
USHSCODE9031808085
UPC
EUHSCODE9013101000
COOCHINA
Card Tracker White Label T1000
x1
USB Cable (Adapter not included)
x1
Card Tracker White Label T1000-A
SKU 114993207
This white-label LoRaWAN tracker integrates GPS, Wi-Fi, and BLE positioning along with temperature, brightness, and motion sensing—all in a compact, low-power form factor. Its neutral, brand-free design supports rapid customization of logos, packaging, and communication protocols, making it ideal for OEM integration, B2B applications, and pilot deployments such as IPO validation and proof-of-concept testing.
USD$39.90
