Product Details
Wiki & Learn
Reviews
Download PDF
Feature
White-label ready for rapid integration
Delivered with a clean, unbranded appearance to support fast OEM deployment—perfect for businesses looking to add their own branding, customize protocols, or scale product lines without starting from scratch.
Note: This is a white-label version with no branding. If you’re looking for the branded SenseCAP version, please check:
What makes SenseCAP T1000 stand out?
  • Feature 1: Seamless indoor and outdoor positioning
T1000 effectively employs BLE and Wi-Fi for pinpoint indoor positioning and utilizes GNSS technologies, including GPS, Beidou, Galileo, and GLONASS for precise outdoor tracking.
Learn how the SenseCAP T1000-A/B is utilized in a LoRaWAN alarming solution for real-time indoor and outdoor tracking, as well as instant alerts. Ideal for schools, industrial sites, warehouses, hospitals, and event venues, etc. Discover more here: LoRaWAN® Badge for Indoor Positioning and Instant Safety Alerts.
  • Feature 2: Credit card size can fit in any application
At a mere 6.5mm thick, this small and slim tracker can easily slip into envelope-like spaces.
T1000 fits in wide range of scenarios:
  • Feature 3: Monitoring Beyond Location
T1000 is equipped with essential features, including a temperature sensor, light sensor, motion sensor, panic button, and buzzer.
The temperature sensor is ideal for monitoring temperature-sensitive goods like food, and the light sensor detects unpacking activities. This data can be utilized for compliance verification.
The motion sensor is useful in identifying if goods are in transit and monitoring potential physical damages. It can report statuses including shock, the start of the movement, the end of the movement, and motionless timeout. Such data can serve as a reference for insurance claims and logistics optimization.
The panic button switches the tracker to SOS mode, which sends data frequently to your platform and triggers the built-in buzzer to alert people nearby that an emergency has occurred.
  • Feature 4: Cheaper in data transmission fee
Using LoRaWAN, the communication costs are significantly lower compared to cellular networks like 4G, LTE Cat-M, and LTE Cat-1. This greatly lowers the barrier to entry for mass commercial use. For instance, with the same amount of data, using a SIM card on other networks could cost up to $3 while with LoRaWAN it is only $0.05.
  • Feature 5: Months of battery after a single magnetic charge
With magnetic charge design to enhance water resistance. (PS: Battery life depends on upload interval, work mode, etc., please refer to datasheet)
  • Feature 6: Never lose track of what was happening - Store data offline when out of connection
  • Feature 7: Built to endure harsh environments
T1000 is with industrial-grade design, equipped with IP65 waterproof protection. It's built to endure harsh environments, with a working temperature ranging from -20℃ to 60℃ (-4 ℉ to 140℉).
Thus, if you're on the hunt for a simple, cost-effective tracking solution, SenseCAP T1000 is an optimal choice, especially in routine areas where activities or movements occur on a regular, predictable basis. This could include a designated route for delivery vehicles to follow, a university campus where students move between classes or a resort where guests visit certain attractions regularly.
General Parameters
Backhaul
LoRaWAN® (v1.0.4 Class A)
Bluetooth
Bluetooth v5.1, setting via App
LoRaWAN Channel Plan
IN865/EU868/US915/AU915/AS923/ KR920/RU864
Temperature
Range: -20 to 60℃ ; Accuracy: ± 1℃
Resolution: 0.1℃
Light
0 to 100% (0 is dark, 100% is brightest )
3-Axis Accelerometer
3-Axis Accelerometer to detect movement
LED and Buzzer
1*LED and 1* buzzer to indicate status
Button
1*Button to operate and trigger events(SOS)
Antenna
Internal (GNSS/LoRa/Wi-Fi/BLE)
Communication Distance
2 to 5km (depending on gateway antenna, installation, and environments)
IP Rating
IP65
Dimensions
85 x 55 x 6.5 mm
Device Weight
32g
Operating Temperature
-20℃ to +60℃
Operating Humidity
5% - 95% (No condensation)
Certification
CE /FCC /TELEC /RoHS /REACH
Location
GNSS Constellation
GPS/GLONASS/Galileo/ BeiDou/QZSS
GNSS Sensitivity
-145dBm cold start / -160 dBm Tracking
GNSS Location Accuracy
~1m CEP, GPS, -130dBm
Wi-Fi Positioning
Passive scanning, uploads the scanned 4 MAC addresses
Bluetooth Positioning
uploads the scanned 3 best signal MAC addresses of Beacon
Data Cache
Cache 1000 data when there is no LoRaWAN network
Battery
Battey Capacity
Rechargeable lithium battery, 700mAh
*Battery Life Estimates
4 months on a single charge(uplink every 1 hour, only GNSS data)
Battery Life Monitoring
Periodic uplink battery level
Charge Cable (Adapter not included)
USB magnetic charging cable, 1 meter
Power Input Voltage
4.7 to 5.5V DC
Charging Temperature
0 to +45℃ (Beyond the temperature range, the charge will be limited, and the LED will blink quickly)
Software
Work Mode
Standby: only heartbeat uplink; Periodic: upload location in intervals; Event: modify the interval by temperature, light and motion(start, end, shock, motionless timeout);
Data Storage
Over 1000 location data records store on the device when there is no LoRaWAN® coverage
App
Configuration via Bluetooth App
Hardware Overview
Certification
HSCODE8526919090
USHSCODE8526910040
UPC
EUHSCODE8517180000
COOCHINA
Card Tracker White Label T1000
x1
USB Cable (Adapter not included)
x1
Card Tracker White Label T1000-B
SKU 114993208
This white-label LoRaWAN tracker integrates GPS, Wi-Fi, and BLE positioning in a compact, low-power form factor. Its neutral, brand-free design supports rapid customization of logos, packaging, and communication protocols, making it ideal for OEM integration, B2B applications, and pilot deployments such as IPO validation and proof-of-concept testing.
USD$29.90
